Question about Toshiba e-Studio 35 Copier
How can I check for the modem - Toshiba e-Studio 35 Copier
  • 95 Answers
Press the fax button on the display - does it go into fax mode (if it doesn't there is no fax board/modem)
look on the back right hand side of the copier to see if there is a place to plug in a telephone cable (it might be behind a clip off cover) - if there is no cable plug then there is no fax/modem.
Posted on Jan 22, 2010
Dell computer modem makes loud rushing sound and won't work
Check connections. Reboot computer. Reboot modem. If no improvement - RESET modem to default. {N.B.: This will remove any changes you have made previously...(Have you checked with the help-desk at your Internet Service Provider?)!} It is usually done by pressing a paper-clip into a hole, usually on the back side of modem, for at least 10x seconds - (check with modem instruction manual). If fault remains after this try another modem. If second modem does the same, then it sounds like a fault in the computer. Check with ISP!
Sorry I can not help more - but you have not given much information; details; etc. I hope this helps - kind regards - 'b'ye - Bruce.
Jul 30, 2014 | Dell Inspiron 531s Desktop Computer
My Dell 2400 mtc2 wont conect tu the intornet. im using a cable model.
Hello Dear,
Things needs to be checked.
1) the Modem. Open Control Panel > Phone and Modem > Modems (make sure your Modem should be listed here) > If yes then CLick on that and choose "properties" > Click on Diagnostics > Query Modem..
It should return some numbers in the dialog box. If not means your Modem is faulty.
2) If modem is OK then first check that your connections are OK. and also check with your ISP that there should not be any issues (Server Down, Validity expired etc)
Hope it help!
With regards
FIXYA team
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
Can I port forward 554 and 8080 in this modem?
Check in the manual if you have it, if not check in google with the model of the modem for it's capacities in the modem specs.
Aug 20, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Modem not detected
check your computer , the PCI device listing says simple comm controller. check your modem device manager see if its visable and not a question mark in the device manager
Jun 08, 2010 | Conexant chipset 56K V.92 PCI Data/Fax...
The lights on my modem aren't on and I can't connect to the internet
Check the cables and check the physical connection
Try to replace the power cord connected to the modem
If Still the modem is not turned on then push the replace button on the bottom of the modem and hold it for 1min and then release it
IF still no go replace the modem
Sep 21, 2009 | AT&T High Speed DSL Modem
My AOpen modem fm56-svv say: NO CARRIER
Assuming you have checked the connection to actually make sure you have dial-tone, you could go into the modem's properties page (Control Panel -> Modems-> Properties) then go into the MODEM tab and make sure to UN-check the box that says "Wait for dial-tone before connecting". Sometime the modems don't detect dial-tone properly.
Sep 03, 2009 | AOpen FM56PX PCI Modem W/Vocie...
Need free download for modem 56k
  • check the system - device manager for sound adapter, checks for any markings on the device red x, yellow ? , or !
  • uninstall and re-install the modem driver, or
  • install the modem drivers
  • or else call a local computer hardware techician to reseat the modem or else replace it.
Apr 14, 2009 | Computers & Internet
Modem disconnection again and again
Its the problem of intermittentconnection.
Check Filters and cables of the modem and telephone.
Check if there is static on the phone line.
Jan 25, 2009 | Intel FM56 / 56k -V. 92 PCI Ambient /...
1st time installation: cannot install modem properly
Hey try this one, if doesn't work let me know. First you have to powercyle your modem - meaning turn it off for 10 to 25 seconds then power it up again. Then check status of the modem lights. It should all be in solid green. Else you have to check if cables are properly connected - Data cable (green cable) one end connected to the filter with labeled "DSL/PHN" or the one with monitor engraved, then other end connected to the green port on the back of your modem. Then check also connection of filter to walljack. After which check status of the lights. If still not all in solid green. Check devices near to your modem, these might be the reason for interference of DSL signal. Electronic such as monitors, speakers... must be 2-3 feet away from your modem. Check modem lights. If all in green, test connection. Also there should only be one phone jack connected to your DSL phone line.
Jan 14, 2009 | AT&T High Speed DSL Modem
Incompatible modem codec detected, please check your modem card.
incompatible modem codec detected please check your modem
Dec 10, 2008 | Arris SM56 (SM-56-PCI) Modem
42 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
