Question about Refrigerators
Hello, \r\nI have a frigidaire, gallery
Hello, I have a frigidaire, gallery professional series refrigerator, model number: FRS26ZSE - (part 218403514) (p/n 218506800) side by side, with ice and water in the door, which was purchased in 1997. I am not able to dispense water from the door, it stopped operating. I have changed the inside refrigerator water filter, and checked the outside bottom water line filter, and water is flowing into the unit. I emptied the ice maker tray, and it is working fine, it is producing new ice daily. When you press the water actuator, you can hear it activate, like it is trying to pump, but no water dispenses. (every once and a while you will get a little water to dispense)? Can you advise on what part I should change out next, is there a selenoid which might be bad?
What would my next step in repairing the unit be?
Where can I get a print on the refrigerator, which lists the part locations and numbers?
Thanks ....In these tough times I am trying to repair myself to save a few dollars?
Thank You in advance!
  • jamber704 Nov 18, 2009
    Hello, our actual model number is FRS2ZSEB1, the print is confusing to me, is this located inside the frigerater near the water filter, or when you are facing the backside of the refrigerater is it on the bottom left rear side, or the bottom rear side where the water intake is located and connected to?
    Is it the part number: PS428394 - Dual Outlet Water Inlet Valve ??
    Where can i get the replacement instructions?
    Thanks
    Thanks the diagram is no real help for me, in looking at it you would think the part is located inside the refrigerator itself.
    So just to be sure what you are recommending;
    If looking at (facing) the back of the refrigerator, I should follow the outside source incomming water supply feed line to where it connects to the refrigerator. On my frig this is the valve located on the right hand bottom side of the frigerater, it has a screen in it which, I had previously checked to see if it was clogged. If I follow the plastic water lines from this valve, one set goes toward the top side of the refrigerator, and a second set goes to left, to a second valve located on the bottom left side of the refrigerator. This second valve is the one I can hear, when you press the water dispensor actuator?
    This is the valve which looks like the one you are linking me to?
    Solution #1
    posted on Nov 18, 2009
    projdoc
    Rank: Guru Expert
    Rating: 94.03% , 590 votes
    http://www.partselect.com/MultiModels.as...
    the top of the page has the diagram. the part you need is right below the diagram (part #141 in the diagram). it's the water valve. after a while the solenoid burns the windings. also check the screen filter inside the valve. if that gets clogged, it restricts the water flow.
    Comments:
    Nov 18, 2009 - follow the water line into the back of your fridge. this should go directly into the valve assy. this is the best i can do in the way of diagrams: http://www.partselect.com/AdvancedModelS....
  • 2,237 Answers
Http://www.partselect.com/MultiModels.aspx?ModelNum=FRS26ZSE&SearchTerm=filter&RefineSearch=0&Page=2
Posted on Nov 18, 2009
  • jasbo
    jasbo Nov 18, 2009
  • jasbo
    jasbo Nov 18, 2009
    there are 2 sets of solenoids. the first has one valve for the water and one for the ice maker (main in, 2 out). that second solenoid, if it's the problem, is part number PS428495. it is a double like the first one, but it's 2 in, one out.
Frigidaire gallery professional series oven I have
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 16, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Freezer ices up and fridge part warm, timer changed worked well for 2 weeks model frt 163ag no frost fridge
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
Dec 17, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Burners wont light
Hello mariagandrad - So I can better assist you, do you happen to have the exact model number?
Sep 30, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Where can I get an ownes manual for the gallerries seies refrigeraor
This is a link to the Frigidair support site for manuals, you will need the Model number. Frigidaire Support. Hope this helps FixYa up.
Aug 02, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hello. I have a Frigidaire Gallery refrigerator. model is FRT22RGCW7 (which i can't find on this website). it was made in May '98. the refrigerator portion recently got exremely cold. freezer...
I used your model # and it came up on frig web sight . but they do not give age to these # only parts info . the age would only be avlb to dealers . i know this didn't ans your question but that info is not avilb. .. sorry mm
Oct 16, 2010 | Frigidaire Gallery Series® GLHT188WH Top...
Fridgidaire Electrolux Professional Series Oven, not preheating
The model number listed in your problem is a refrigerator.  Go to:
http://www.frigidaire.com/manuals.aspx
and enter the model number of your range/oven unit to find the user manual.
On my GE range I only have to press and hold the LOCK button for several seconds (until it beeps) to unlock it.
May 28, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
