Question about Linksys Wireless-G WRT54GS Router (e125894)
I have vonage telephone hooked up to my pc.how do i install my wrt54g router,what wires go where?
  • 2,260 Answers
Who is your ISP. I think your modem is connected to the Vonage and Vonage is connected to the computer. If that is the connection then you can disconnect the computer from the vonage and connect the router there. From the vonage connect to the internet port of the router. then connect your computer to the router. Check if that works. If you are connecting the router to the modem, then you will need to set up the router as per the modem set up or type of ISP. Click Here for step by step solutions
Posted on Nov 17, 2009
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 20, 2011 | Belkin Computers & Internet
I have forgotten all details of password to change my entry into Wireless-Gv Broadband router WRT540.I need its passport to establish a Wi-Fi connection for my Amazon Kindle.William D. Little
Default backdoor passwords
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
WAP11 MULTI n/a (none)
LINKSYS DSL TELNET n/a admin
LINKSYS ETHERFAST CABLE/DSL ROUTER MULTI Administrator admin
LINKSYS LINKSYS ROUTER DSL/CABLE HTTP (none) admin
LINKSYS BEFW11S4 Rev. 1 HTTP admin (none)
LINKSYS BEFSR41 Rev. 2 HTTP (none) admin
LINKSYS WRT54G HTTP admin admin
LINKSYS WAG54G HTTP admin admin
LINKSYS LINKSYS DSL n/a admin
LINKSYS WAP54G Rev. 2.0 HTTP (none) admin
LINKSYS WRT54G Rev. ALL REVISIONS HTTP (none) admin
LINKSYS MODEL WRT54GC COMPACT WIRELESS-G BROADBAND ROUTER MULTI (none) admin
LINKSYS AG 241 - ADSL2 GATEWAY WITH 4-PORT SWITCH MULTI admin admin
LINKSYS COMCAST Rev. COMCAST-SUPPLIED HTTP comcast 1234
LINKSYS WAG54GS MULTI admin admin
LINKSYS AP 1120 MULTI n/a (none)
LINKSYS PAP2 / PAP2V2 (VONAGE) HTTP admin admin
LINKSYS RT31P2 (VONAGE) HTTP admin admin
LINKSYS RTP300 (VONAGE) HTTP admin admin
LINKSYS WRT54GP2 (VONAGE) HTTP admin admin
LINKSYS WRTP54G (VONAGE) HTTP admin admin
LINKSYS/ CISCO RTP300 W/2 PHONE PORTS Rev. 1.0 HTTP admin admin
LINKSYS/ CISCO RTP300 W/2 PHONE PORTS Rev. 1.0 HTTP user tivonpw
also, holding the reset button for about 30 seconds will clear the password usually.
hope it helps.
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Oct 28, 2010 | Linksys Wireless-G Broadband Router
I just Bought the HP Officejet All-in-one J4540 Printer. I am also using Vonage as my phone source. I have high speed broad band internet cable. How must my phone jack hook ups be configured to send and...
Since a fax works over an analog telephome signal this is no different when you hook up a phone to your vonage. I believe you hook up a regular telephone to your vonage router via a telephone jack in the back of it. If so plug the fax machine into it via a splitter
Nov 25, 2009 | Office Equipment & Supplies
Having difficulty installing DL 624 with vonage
On my Vonage setup, I had to hook the Vonage unit's blue port to the Cable modem, then connect the router to the Vonage's yellow port.
For some reason, the router would not assign an IP to the router the other way.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
How can I install my fax HP640
All fax machines are ANALOG devices. They are designed to work on POTS (Plain Old Telephone System). Any other condition is a **** shoot.
Jul 21, 2008 | HP 640 Inkjet Fax Machine
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
Lose the internet signal frequently. Vonage now set on and I can't afford to having to reset the router constantly. I have a t54g and wonder if I need to change my router. I only have a main computer,...
Do you have cable TV also? If so, how many TVs are hooked up. Sounds like you have signal loss. I had the same problem. Also, if you have another coax cable lying around, try changing it out (from the wall to the cable modem, cables can be a big issue with this).
Apr 26, 2008 | Linksys Wireless-G WRT54G Router
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
180 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
