Question about Frigidaire FRT18S6AW Top Freezer Refrigerator
LEAKS WATER ON TOP SHELF OF UNIT - Frigidaire FRT18S6AW Top Freezer Refrigerator
  • 612 Answers
You most likely have a stopped up drain in the freezer. When the freezer goes into defrost, the water drains out and down the back of the unit. Into a pan located on top of or close to the compressor. You will need to unclog the drain.
Posted on Nov 17, 2009
Lg refrigerator leaks water inside
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
Sep 28, 2017 | LG LSC26905TT Side by Side Refrigerator
Frigidaire frt18s6awy
Do you notice where the water is coming from? Like a nearby shelf or an ice build up? Ice build up indicates an air leak.
Jul 22, 2012 | Frigidaire FRT18S6AW Top Freezer...
Fridge leaks on the inside
The drain line in the freezer is blocked. It drains the water away after the defrost cycle. You will need to post your model number for me to be of more help.
Mar 30, 2012 | Refrigerators
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
Water leaks into fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 20, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Water leaks inside fridge from top freezer
check your gasket on the refridge door see if it has any rips or you have a blocked drain in freezer
May 02, 2009 | Refrigerators
Defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Feb 25, 2008 | Whirlpool (ET8FTEXSQ) Top Freezer...
Frigidaire FRT18S6AW Top Freezer Refrigerator Logo
149 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
