Question about Apple MacBook Pro Notebook
I dropped my macbook pro a few weeks ago. Everything was working normally, even the cd drive, which is on the side where I dropped and heavily dented it. The worst of it seemed to be that the casing is so dented that my computer won't stay closed. I had plans to get the dents repaired and everything checked out a couple weeks from now when I will have less constant need of my computer for a while, but now I'm worried that something is really wrong, and by using it the way I have been, I'm making the problem a lot worse. There is a weird thing happening with the fan, but it doesn't seem that bad on its own, just now that I'm having these other problems. I have smcfancontrol, and normally, my fans would be running in the 1000-3000 rpm range, only getting higher when the temperature was above 60C or 70C, which only happened when I was doing the normal things that overheat computers, like streaming video while holding it on my lap. Now my computer will be flat on a desk, at 40C or 50C, and running at 6000-7000 rpm! It isn't quite constant, but it happens very often. It does seem to have something to do with how much cpu I'm using, but shouldn't it have more to do with the temperature? And I'm not doing anything new with my computer that I wasn't doing when the fans were behaving normally. The sleep problems are worrying me much more. As I said, my computer won't stay closed, it pops open just a little bit. If I hold it closed, it will fall asleep. For several weeks after dropping it, I had no problems with sleep, I would hold it closed, it would fall asleep, it would pop open slightly, when I wanted to use it again I would open it all the way and it would wake up normally. Now, whenever I open my computer, it's off. I move my computer around a lot, and it doesn't seem like I should be booting it up this often. The first time this happened, I had left it unplugged and asleep overnight, and the battery was exhausted when I went to open it in the morning. This seemed strange, since I've often left it unplugged all night with no problems, but at least it being unplugged for a long time explained why it turned itself off. This has now happened several times, plugged, unplugged, fully charged, barely charged, after being asleep for a short time or long time. I've looked through some forums, and I've tried a couple things, like turning off time machine and changing the sleep mode every which way. It doesn't seem to have made any difference. All my firmware and software is up to date. Also since it is booting up several times a day I've noticed that it takes at least 5 minutes to boot up. Is there anything else I can do to try to fix this problem on my own? Should I keep it plugged in and open and stationary all the time until I can get this fixed? Should I stop using my computer entirely until I can get this fixed?
  • Apple Expert
  • 481 Answers
I'm going to tell you what the Apple tech will tell you, because it's true:
In many cases, the damage and the system failure do not occur at the same time. Sometimes, a customer will drop a system or spill something on it and find that the system continues to work for a while. Sometimes components can crack upon impact but the electrical and data connections may not open or short until well after the crack occurs. This can be due to flex on the system chassis or expansion or contraction with temperature change. Another example occurs when a hard drive is damaged by an impact but may continue to work at a lower standard of performance. In some cases, quite some time may pass before the unit finally fails.
Further bad news is that accidental damage is not covered by product warranty, including Applecare extended warranty, so the cost of the repair you need may be significant.
I'm sorry to have to be the bearer of bad news here, but my recommendation is that you repair or replace this computer ASAP.
Posted on Nov 18, 2009
How do I upgrade my macbook pro hard drive?
If this is the 2009 model with the DVD/CD drive, then you can add up to 8GB of RAM and a much larger hard drive. I have seen drives up to 1.5 TB, and they were not expensive (just over $100). Just search for an online retailer (or go to a local Apple service center) that specializes in upgrades for older MacBooks. You may need a special set of tools, and you can also buy a kit that will allow you to use your old hard drive as an external drive (but make sure you back everything up BEFORE you start to swap drives).
Jul 17, 2014 | Apple MacBook Pro MB991LL/A 13.3-Inch...
1). Dropped MacBook Pro (While off, Battery Fully Charged, Normal working condition) 2). Turned on to see if okay... 3). Heard it begin to boot up like it normally does... 4). Immediately turned back...
Very difficult to tell what could have go wrong. Could be a connector, could be a chip. Even a flatcable or a motherboard can be dammaged. Online you can get service manuals and there are video's about how to open and close Macbooks. Still I do have to advice not to open a laptop, if you don't have any skills in repairing electronic equipment.
Oct 30, 2013 | Apple MacBook Pro Notebook
Why can't I get a home dvd to load to my MacBook Pro?
https://itunes.apple.com/gb/app/free-dvd-ripper/id625150797?mt=12
Feb 27, 2013 | Apple MacBook Pro Laptop Computer with...
Macbook pro disc drive ejects everything
Try using a cd drive cleaning disk. Costs around 15 dollars.
Dec 18, 2012 | Apple MacBook Pro Laptop Computer with...
Why does my macbook keep ejecting CDs and DVDs out whether they are blank, burnt, or regular?
The unit is fubar and needs to be replaced since repair is not cost effective.. You might open up unit to see if there is any debris in the path of the tray that could be interfering in its operation. If all is ok,time to go shopping.
Sep 02, 2017 | Apple MacBook Pro Notebook
Can no longer burn cds on MacBook Pro (Model A1226)
Get a cheapy drive cleaner/laser cleaner. Looks like a normal CD/DVD, but has a brush on one side. Should be able to pick it up from an electronics store/supermarket. Pop it in, watch it go, then try again afterwards. I've detailed this further in a blog posting at <a href="http://www.garysmith.org.uk/blog/index.php/blog/show/Matshita-DVD-R-UJ-857E-problems---dirty-laser.html">http://www.garysmith.org.uk/blog/index.php/blog/show/Matshita-DVD-R-UJ-857E-problems---dirty-laser.html</a> - there's a few comments on there about it, pretty much all of them saying that it's worked for them. I guess with it being a slot loader it's perhaps a little more open to getting dust inside. Hope that helps.
Thanks,
<a href="http://www.garysmith.org.uk">Gary Smith</a>
Jun 04, 2009 | Apple MacBook Pro Laptop Computer with...
MacBook Sound Driver Issues
Sounds like the cutout switch in the output jack is stuck open, it is a techy fix sorry (at least it is not a board failure)
Jun 02, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
INTERIOR LIGHT AND CD PLAYER STAYS ON EVEN AFTER THE CAR IS SHUT
Sounds crazy but have your Alternator checked?
Sometimes things will act up in your car if your alternator is trying to quit on you!! happened to me.
i thought the mechanic was nuts but once it was changed everything went back to normal.
Jan 15, 2009 | 2005 Chevrolet Cavalier
I have a SanDisk Sansa m200 mp3 and a macbook pro
Even on a Macbook pro, you should be able to access your "my computer" option, where it shows you the local disk drives and everything. your mp3 player icon should appear there. then after you click on the icon it should bring up a page containing folders "on" your mp3 player. there doesnt have to be any music or videos or anything like that to have the folders already on there. now i dont have a mac but what i suggested you to do should work.
Sep 14, 2008 | SanDisk Sansa e200 MP3 Player
Macbook DVD drive
I wonder if the DVD is a faster disc than the Mac can handle. I know that when I use a 40x CD disc on a G5 optical drive, it's no go. But if I use a 4x disc, it's a happy camper. I bought an external drive to handle the faster discs.
Sep 07, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Pro Notebook Logo
1,189 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
