Question about American Standard Home
I need a nut for bolt to floor - American Standard Home
  • 71 Answers
Aftermarket nuts & bolts are available at hardware stores - & anywhere that sells toilets. Usually brass or other non-rusting material.
Posted on Nov 17, 2009
2010 malibu the two bolts that hold the drivers seat rail the nuts that are securing the bolts seem to have broken loose if I take the bolts out and the nut drops how do I reinstall
The nuts should be captive and welded to the frame of the car, actually if I remember correctly, they should be studs welded to the body/ frame and nuts should hold the seat to the floor.
Jun 20, 2017 | Seat Cars & Trucks
How to remove back seat of hhr 2006
Rear Seat Replacement
showgif.do?image=1592810
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedure Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement .
Nut, Rear Seat (Qty: 6)
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N?·m (33 lb ft)
Bolt, Rear Seat (Qty: 3)
Tip
  1. Adjust the seat forward or rearward to access the bolts.
  2. Remove the plastic trim pieces to gain access to the nuts.
Tighten
45 N?·m (33 lb ft)
Rear Seat Assembly
Oct 28, 2015 | Seat Cars & Trucks
How do I secure my safe to the floor/
Drill holes through the bottom, open the door and mark the hole locations on the floor. Attach bolts to the wood or concrete floor, lower the safe over the floor bolts, and fasten nuts with lockwashers onto the bolts inside the safe. When the door is closed no one will be able to undo the nuts. Or use heavy duty lag screws tightened from inside the safe. This will prevent the casual picking up of the safe and slow any thief down.
Oct 10, 2014 | Home Security
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
Jan 12, 2011 | Eljer 141-0220-00 Toilet Tank White
The two bolts that holds the toilet bowl down. one on each side. the whole things turn ad i cannot take it off
a lots of the time when that happens you will need to use a grinder or a ' Dremil ' tool to cut the bolts that are holding down the toilet and get some new bolts and re-install. **** there is also a chance that if you CAN turn the bolt itself from the top that you can get the bottom of the bolt ( which is ' T ' shaped ) to turn in the right direction and get the bolt head to slip through the slots in the floor plate. since you will most likely need new bolts to re-install the toilet, go buy the new bolts at the hardware store and by looking at the bolts and looking at a floor plate at the store -- this will give you a idea of what you are trying to remove.. ( it is kinda like a puzzle ). ******
also --- sometimes you can get a hacksaw blade ( by itself -- not on handle ) to fit between the floor and toilet and cut the bolts that way,, this is kinda a pain to do, but in a pinch it sometimes works good.
I hope these ideas help you --- good luck ( ! ).
c...
Dec 31, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I do not know how to remove front seat from a 1994 chevrolet beretta cp
hmm,, ok,, try this..
1.) look under the seat you will notice two sliding rods,, on this there are 4 brackets with bolts.. its maybe hidden under the upholestry,, any way remove the bolts,, slide any lift seat..
Oct 12, 2010 | Chevrolet Beretta Cars & Trucks
Climate control will only blow cold air and the heater core is fine there is heat. when i turn the climate control to hot there is a clicking noise, when i turn it back to cold the click goes away
your blend door actuator gear is slipping. remove actuator and check blend door for free movement. If jammed, you may have to open the system to unjam. If door is free to moe, replace actuator. See procedure below to access blend door. Not sure you need a lift, as long as you can get the 2 nuts off under the truck.
Removal & Installation
  1. Position the vehicle on a hoist with the gear selector in NEUTRAL.
  2. Remove the left-side quarter trim panel.
  3. Remove the parts in the order indicated in the following illustration and table.
Fig. Blend door actuator - auxiliary
(1) Auxiliary line floor pan bracket nut (2 req'd)
(2) Auxiliary housing bolt
(3) Auxiliary housing bolt
(4) Auxiliary housing nut
(5) Auxiliary harness electrical connector
(6) Blend door actuator electrical connector
(7) Screw (3 req'd)
(8) Blend door actuator
To install:
  1. Installation is the reverse of the removal procedure.
  2. Observe the following tightening specifications:
    Auxiliary line floor pan bracket nut (2 req'd), 71 inch lbs. (8 Nm) Auxiliary housing bolts, 62 inch lbs (7 Nm) Auxiliary housing nut, 62 inch lbs (7 Nm)
Oct 03, 2010 | 2004 Ford Explorer
How do i replace my starter for my 1992 Lincoln Town Car?
First disconnect battery. Use a floor jack to lift vehcile from passenger side. Use floor jack to help hold up car for safety. The starter will be located ton the passenger side. It is held by two bolts. There will be one wire to a 10 mm nut. remove. There will be a couple of wires in cluding one from the baterry to a big bolt remove the nut. Remove the two bolts being careful as starter may drop. You can use the floor jack to help you since the floor jack is suppporting the vehicle. Reinstall in reverse.
Nov 17, 2009 | 1992 Lincoln Town Car
The bolt that holds the seat belt to the car floor is stripped with the plate also? I can't get to the bottom of the plate under the truck to put a longer grade 8 bolt and an aircraft lock nut?
you can drill out the plate and the floor and put in a bolt and nut,useing washers of course.i can't be more specific,i don't know what your vehicle is.
Oct 08, 2009 | 2002 Hummer H1
Home Logo
81 people viewed this question
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
