Question about Fuji Finepix A610 Digital Camera
When I switch the camera on, the lenze extends as normal, but most times the screen stays blank, There is nothing wrong with the screen as I can switch to look at previouse photos, but when I want to take a picture the screen goes blank.
5 Suggested Answers
SOURCE: has always worked fine, til just now. took a
for your information the computer has nothing to do with the focus error!!!!
the error appears as a message due to either of these reasons.
  1. you have dropped down the cam.remember even a small drop may cause the lens to be damaged
  2. you have forced the lens to close inside
  3. the software inside the cam had been corrupted(not the one that came as an installation disk)
a more complicated problem could have happened to which can be found only after a physical examination of your device.so please take it to the nearest service center to get it repaired for free if its covered under warranty!
please do not try to disassemble it unless you know how to do it well!
thanks for contacting fixya!
Posted on Oct 22, 2009
SOURCE: View old photos but can not take photos
I have the exact same problem on my finepix, it occured today when I was uploading pictures and the battery on the camera went out... Maybe its bricked or something such... Ive searched firmware downloads but no success..... So Im also hoping someone has a solution...
Posted on Jul 15, 2010
lock123
  • 6831 Answers
SOURCE: Zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 02, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: has a message Zoom error and there is a grating
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Mar 15, 2011
Hi. Does anyone have a canon SX510 HS. If so can you please answer step step on where to go to reset the camera as my screen is blank. Like how many clicks left, right down or up. I use my camera all the...
Why do lots of people think a defective device will be healed with a reset? A camera, only has a microprocessor and a little program that runs from a flash memory. When something goes wrong in the ram part of the memory while running the program only one kind of reset exists. Just switch of the camera and one step extra, remove the battery. After replacing the battery and switching on, all software errors should be solved. Any hardware error will stay as it was.
Most settings, like switching off the display will stay as they were.
Perhaps you try pressing the display button several times, and look if the screen (display) will give what you expect.
Don't forget, if it works.
Jan 16, 2015 | Canon PowerShot SX510 HS Black Digital...
My cam does seam to zoom right
Check the settings. If that's not it one of the lenzes might have been nudged/pushed in or out a bit. If that's not it you may just have a lenze that was cut wrong...maibe some one replaced it with the wrong lenz.
Sep 06, 2011 | Vivitar Video Cameras
I have a camcorder JVC GR-DX67EK which worked fine and suddenly as I started it up the message "Lenz Cap" came up (as it normally does). But this time, it didn't clear up as I removed the Lenz...
Look for a switch somewhere around the lens that is probably stuch triggering the OSD to display "Lens Cap". You may have to depress nthe switch with a toothpick or paperclip. Look at the lens cap for something sticking out of it. That would be the actuator. Line that up and you should then find the switch.
Mar 13, 2011 | Video Cameras
Fe-310, only used a few times, kept protected, one
Short answer - yes.
Manufacturers have become very good at making products that are reliable for exactly 1 year.
Usually it's small components that have a deffinate shelf life.
I would first check that you are using the correct battery for it. Even if it looks like it takes standard AA's - they often will only work for original spec rechargable blocks.
If this does not solve it - write a letter to Olympus saying how dissapointed you are with their product.
They may offer you a good deal on a repair hopefully.
Unfortunately Sony and HP are even worse - HP and lexmark printers now stop working after a period of time - telling you to buy more ink - even though you still have plenty.
Oct 01, 2009 | Olympus FE-310 Digital Camera
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
Eror e6100 flashing
error is generic hardware error. normally some part of the infrared or display has malfunctioned.
Feb 02, 2009 | Sony Cyber-Shot DSC-P71 Digital Camera
Lenz stuck out
If the lens mechanism has been damaged or is sticking from foreign material around the lens housing it will shut down when you try to power on. Once in a while you can try to assist the lens by placing gentle pressure against it when you power on and the lens may retract. This will most likely not fix the problem but it may give you a better idea if the mechanism is damaged or not.
Sep 20, 2008 | Kodak Easyshare M753 Digital Camera
Blank screen
Usually it's an lcd burn out where the screen needs replacement. Check the display button if it's just blank then press it to see if it comes on. As far as your friends white screen it not feasible to repair. A good thing to get on any digital equipment is an extended warranty. It does save you in the end when something goes wrong. The limited manufacture warranties are a joke. You should never rely on them.
May 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Fuji Finepix A610 Digital Camera Logo
22 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
