Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
It appears my ec12 lost some type of valve cap. The valve is located on a copper fitting under the pressure relief valve. Never saw it before. Don't know what i'm looking for.
  • 530 Answers
I want to be sure we are talking about the same. Most likely your compressor has only one safety valve however since it can come with two I want to be sure which one you are referring to. The first will be located on the bottom or back side of the pressure switch. The second if installed is located on the tank check valve. I assume you are referring to the one on the switch correct?
If this is the case then please let me know exactly where this cap was located. You stated it was located under the relief/safety valve but it's not part of the valve correct?
Is it part of the manifold attached to the bottom/backside of the switch?
Although the pic is a generic switch it will help if you can tell me if the location A or B is where you think it came from.
The black line is there because a lot of switches have a flat bottom and some have a small cap to seal off an additional port/ports.
Most switches are not produced by the compressor manufacturer. Because of this many are used on a number of different models as well as a variety of compressor manufacturers. To accommodate as many as they can switches sometimes have ports that are sealed off using a cap or large allen head plug when the compressor does not utilize all the options available on the switch. This is most likely what the cap is for.
Still I want to be sure so again take a look at the pic and if possible give me a general location.
I'll be waiting your reply.
http://www.hitachipowertools.com/product/files/pneumatics/compressors/EC12_E4_BD.pdf
Posted on Nov 17, 2009
1990 triton oil pressure relief valve location
Hi Lee, There are two oil pressure relief valves on most vehicles. One is fitted onto the oil pump assembly and another onto the oil filter housing assembly. The oil pump pressure relief valve is located at the front of the engine and is accessed via a blind nut on the side of the unit. The bolt is in the form of a cap, which when removed can be seen to be holding down under tension a spring, which in turn presses the valve. If the pressure becomes too high the valve body is pushed upwards and releases an amount of oil, thereby maintaining the required pressure. The valve built into the oil filter housing works in much the same way, but its job is to allow oil circulation in the event of a blocked oil filter. regards John
Feb 11, 2012 | Cars & Trucks
Unable to locate what I think is the pressure relief valve located under the on/off box. looks like a small needle valve but leaks air constantly. any ideas?
If it leaks constantly until the tank is empty or very low, the problem is most likely a leaking check valve. The pressure relief valves mission is to empty the pressure line between the chech valve and the sylingers to facilitate unloaded restart of the motor. The check valve is usually mounted directly on the tank an connected to the large copper tube from the sylinders as well as the relief valve through a smaller and thinner tube (often nylon). Empty the tank, unplug the power and open the unscrew the cap of the check valve and retreive the spring and the valve disk and inspect for damages, foreign objects or replace if needed. Refit it and test run the compressor. If your problem is that the relief valve leaks only while compressor is running and just after it stops, the problem is likely to be the relief valve itself. This is usually an integrated and rather delicate part of the pressostat (pressure, on off switch box) and you may need to replace it as a unit unless you can clean it by pressurized air or gently dismantle it for inspection and cleaning or removing foreign objects or dirt.
Feb 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Compressor pumps up fine but then leaks air just below the relief valve. out of a small factory hole in a brass fittting and goe down till compressor starts again.
When the unloader leaks as you describe indicates that the check valve is leaking. Easy to check the condition of the valve. Follow air discharge line from compressor head to tank. The brass or steel fitting that threads into tank is the checkvalve. Remove all air from tank and remove large inspection cap to reveal the teflon seat. If it is cracked or swollen you will need to replace the valve. Parts available at www.toolpartsdirect.com Good luck
Sep 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
REPLACEING FUEL FILTER
Pressure Relief
Special Tool(s) EFI/CFI Fuel Pressure Gauge
310-012 (T80L-9974-B) swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Fuel in the fuel system remains under high pressure even when the engine is not running. Before servicing or disconnecting any of the fuel lines or fuel system components, the fuel system pressure must be relieved to prevent accidental spraying of fuel, causing personal injury or a fire hazard.
  1. Remove the schrader valve cap and attach the EFI/CFI Fuel Pressure Gauge.
    NOTE: Open the manual valve slowly to relieve the system pressure. This may drain fuel from the system. Place fuel in a suitable container.
    Open the manual valve on the EFI/CFI Fuel Pressure Gauge slowly and relieve the fuel pressure. 9deacdd.gif
    Filter Removal
    1. Relieve the fuel pressure; refer to Above.
    1. Remove the fuel filter (9155).
      1. Disconnect the fuel lines
      1. Remove the fuel filter from the fuel filter support.
      1. Push Connect Fittings
        Special Tool(s) Fuel Line Disconnect Tool
        1. Relieve the fuel pressure; refer to Pressure Relief in this section.
        1. Disconnect the safety clip from the male hose.
        2. Install the fuel line disconnect tool and push into the fitting. f0af03c.gif
          Install the fuel line disconnect tool and push into the fitting. 367328f.gifSeparate the fittings.
          • Inspect for damage.
          • Clean the fittings.
Sep 02, 2010 | 1998 Ford Explorer
My Hitachi EC12 builds pressure, shuts off, then air escapes
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12. I have also changed to 100% synthetic oil.
May 15, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My Hitachi EC12 builds pressure, shuts off, then air escapes through the relief valve for a period of time, sometimes shorter sometimes longer. If longer, the compressor switches on again, but has trouble...
the problem is in the check valve where air enters the tank.when leaking it lets air pressure up to the air piston causing the motor to stall upon restart.replace check valve.average cost of part 15 to 30 dollars.simple fix
Mar 29, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Ec12 hitachi air compressor will not build pressure higher than 40psi
most likely the the reed valves are stuck or miss aligned. Worse case senerio your piston seal blew causing this not to build pressure. Read manual on how to disassemble head. to remove should be 4 bolts and your copper line, just be careful of the reed valve plates, they are thin steel that sit into the head. Put back the same way you took it apart.
Feb 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Where is the power steering container located.
The power steering pump is a CB-series, vane-type positive displacement pump with an integral fluid reservoir. A pressure relief valve limits maximum system pressure, and is located inside the flow control valve in the pump housing; the relief valve is not serviced separately. The power steering pump is driven by the engine via an automatically tensioned drive belt.
Just Fallow the Belt and Look for the ONLY Component that Has A Cap on it
PLEASE DONT FORGET TO RATE ME
Jan 21, 2009 | 1998 Buick LeSabre
My EC12 builds up pressure, but then releases all but about 10 psi.
The non-return valve is sticking and it's an easy fix. First, for safety, unplug the electric power to the unit and release any pressure in the tanks. Then unscrew the cap of the non-return valve (between the compressor and the tanks). Inside you should find a tapered rubber plug which is probably sticking in the valve housing. Sand down the diameter of the large end of the plug, being careful not to damage the flat face at the narrow end (which is the sealing surface). For sanding try 400 or 600 grade wet-or-dry paper and sand until the plug just moves freely in the housing. Reassemble and the compressor should work. Incidentally it's an oil-type unit, and quite durable. Make sure it has enough oil.
Sep 23, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
91 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
