Question about Mintek DTV-263 26 in. LCD Television
After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
    Problem Solver:
  • 9 Answers
The dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
Posted on Nov 17, 2009
Hi, I have a Sharp DV-RW360H which has been working fine. I have dubbed various VHS tapes to DVD and now need to finally the discs so they can play in other machines. However when I press the setup button...
Try one of the discs in another machine. You only need to finalise them if you want to ensure no more is put on them. To finalise a disc you need to use the write or burn functions, not the setup menu. Get the manual for this from the sharp website and read it.
Dec 15, 2013 | GoVideo DV2130 DVD Player/VCR
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
The chapter title on Avatar keeps popping up in a box starting about chapter 14.the longer the movie goes the more often it pops up and the longer it stays on screen.i have a bd-hp22x model.
try to play this disc on another set to check for any errors, this could also lead to tricking the micro to shift the menu. Also load the cd next time and click on required fileds only, also avoid the sub titles and check again..
Jun 29, 2010 | Sharp AQUOS Blu-ray Disc Player
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. stacy_sunshine_t@yahoo.com if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
Mintek DTV-263 26 in. LCD Television Logo
170 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
