My whirlpool washing machine is getting stuck in the wash cylcle right before it is to drain
  • 5,911 Answers
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and there will be no small hole on the right hand side of the wash tub. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best deal.
This is a very simple repair, but if you have questions, please post back with a complete model number (usually located around the wash tub rim under the lid) so that I may be able to provide you with better assistance. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Posted on Nov 17, 2009
How can I unlock my Whirlpool duet washing machine?
Probably something stuck inside drain pump or pump is defective. Unplug machine. Take filter out of Pump to see if there are any obstructions. After you get pump issues fixed, plug back in and door should unlock.
Nov 01, 2017 | Whirlpool Washing Machines
Wfw9150ww00
Make sure your washing machine is on level ground, if the machine is off balance it will stop.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer has stopped and won't move on to rinse cycle and won't drain. It's done this before but if I jiggled the lid, it would continue. That is no longer working. The washer has finished the wash cycle...
Its the lid switch that is defective..located under the top panel portion of the machine and engages the lid when it shuts as a safety device....unplug and try to locacte it yourself.
Feb 23, 2011 | Estate TAWS800JQ Top Load Washer
Power is on, still will not start
Too many clothes
washer door not opened between washes
low power/extention cord
kinked hose
Door not shut tightly
hoses connected backwards
inlet screens clogged
circuit breaker tripped
unbalanced load
excessive suds
wrong detergent
Repair Manual
Jan 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The spin cylcle does not work . It makes a funny noise and does not spin
the drain is probably clogged you'd be surprised home much is in there
Apr 26, 2009 | Washing Machines
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
