Question about Xerox Office Equipment & Supplies
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
HI, MY XEROX 1045 COPIER has been making good copies for me. About one hour ago, I noticed that the toner light came on. I did not want to change the toner, as the copier am still making high quality copies. After the last copy I made, it started a continuous slow paced ''clicking'' sound and won't stop. I tried turning it off and one. I tried removing & replacing the same toner & drum. There is no code displayed. What can I try to get it to operate again? If this problem is due to low toner, is there a TONER override/reset procedure that I can use? If yes, what is it?
I know of the DRUM override/reset procedure for error code J2, but I don't know anything for this toner. Can you help me? thanks
  • mryberg Nov 19, 2009
    NO it is not a drum problem, I replaced the toner & copier is working fine.
  • 17,970 Answers
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Posted on Nov 17, 2009
Copier keep making noise while copying
Do you see any issue with the print quality? If everything is working ok and it's still making a noise call your photocopier provider.
If you dont have one, i work for a xerox partner. Either call or email us and i will get someone to advise you.
Mar 19, 2012 | Xerox CopyCentre C20 Black and White...
Area where final copies come out of machine making
Sounds like the output clutch. Take the top off the fuser area and clean the clutch.
Dec 04, 2009 | Xerox WorkCentre 432 ST Copier
My copier will not feed paper through the auto feed and now a line is on every copy when i make a copy
Sounds like you've got something jammed in the ADH. Have a good look under the cover on the side where there is a narrow glass strip..
The line is caused by a mark or spot on this narrow glass. As the original passes over it a small spot will be picked up as a continuous line.
Sep 24, 2009 | Xerox Office Equipment & Supplies
Error code E701
Е-701 the malfunction on frequency temporary signal, which can arise out of for undue execution temporary parameter. The Sensors fix time of the passing the paper in feeder, it not always coincides. You it is necessary to apply to service service and do service. This not big worries. Good luck!
Sep 13, 2009 | Xerox 8830 Copier
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
Trying to get my Ricoh Aficio 1035 networkable
This is all you need to upgrade your copier to a network printer/scanner and fax.
Good Luck.
32MB Memory Unit Type B 400516
Postscript 3 kit type 1045 410713
64MB Memory Unit Type B 400517
Fax Function Upgrade Type 185 410284
Print Unit Type 1045 410706
Printer/Scanner Unit Type 1045 410699
Network Interface Board Type 1045 410714
Fax Option Type 1045 410680
Fax Stamp Marker Type 30 334049
Jul 08, 2009 | Ricoh Aficio 1035 Copier
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Quality of printed color copy
sorry, I didn't notice that you had indicated the model. This machine likely needs a technician to clean the unit...primarily the laser optics, and transfer sections, I would say
Feb 14, 2009 | Xerox WorkCentre M-24 Color Copier
245 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
