Question about Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator
Lower door wont stay closed
The lower door (freezer) seems to lose it's seal and come open as the upper door is closed. It doesn't seal well. The actual door seal appears to be fine and nothing is pushing against the door. I get the impression there is some type of vent in the system that is not working properly?
  • Boogies Aug 25, 2008
    We have a top freezer. We had a power outage for about 12 hrs. and when the power returned the freezer door pops open every time the refrigerator door is shut. I've cleaned and dried where they meet but it is like there is only a little magnetic sealing. Up until that happened it was so strong if you tried to reopen the freezer you would have to pull hard.
  • 833 Answers
I doubt it. The problem is probably that the unit is on an uneven or unlevel floor. Make sure all 4 corners are 'solid' and the unit is level. Is the door overloaded? Any hinge damage to either door or loose hardware?
Posted on Jan 10, 2008
6ya staff
SOURCE:
Why Bottom freezer drawer wont stay open
Freezer and refrigerator doors aren't usually supposed to stay open. The units are usually installed so that they're slightly tilted to the back to make sure gravity will close the doors if you forget to. If you are SURE - I mean really SURE - that you want your freezer to stay open you should check the drawer rails to see if they're adjustable; if they are, trying raising the back of the rails (or lowering the front). If the rails are not adjustable, try adjusting the front feet of your fridge so that the front of the whole unit is just a tiny bit lower than it is now. Don't lower it too much! If you do, the doors won't stay closed; they'll leak cold air and you'll lose food.
Jul 18, 2014 | LG LMX31985ST Super-Capacity 4 Door French...
Freezer door opens when fridge door is closed
that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
May 01, 2012 | Maytag Refrigerators
Door needs to be adjusted as it seem to be hanging lower on open
slightly loosen the bolts on the hinges enough to scoot the door into the correct position and it will stay until you tighten the bolts on the hinges. It may take a couple of tries but that is the way to do it until the door seals and closes properly =)
Jun 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer drawer jars open at upper right corner when refrig door is closed. Air leaks in and is forming frost on frozen food.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Nov 05, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Freezer door stays ajar after closing the refrigerator door.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator door will not stay closed
Sep 25, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer door will not stay closed when closing refrigerator door
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Sep 04, 2009 | Refrigerators
Refrigerator Door won't stay closed
Part 12 on this diagram is your cam. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB27FHSS02&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=O2030395&backToLink=Return%20to%20Sub%20Components%20list
Aug 19, 2009 | KitchenAid KSCS25FKSS Side by Side...
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Top freezer opens when lower door is shut
This could be the door rubbers, try boiling some water and pour it slowly over the rubber,it would turn soft and wold return to the original state.
now close the door and with a hair dryer set on hot,blow on the rubber untill it seals all over.
let the door stand close for at least 6 ours...
Let me know if it worked..
Good luck.
Sep 09, 2008 | Kenmore 72073 Top Freezer Refrigerator
Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ Bottom Freezer French Door Refrigerator Logo
198 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
