Daewoo washing maching DWDe1211 error code E8
  • rogeng Nov 17, 2009
    could it be heater relent
    Genius:
  • 1,416 Answers
what this simply means is that there as been an over flow of water in to the panel that is the reading sensor (lens)
what you are to do to fix up this problem is to unscrew the washer by the screws with a screw driver (technician tools) then clean up all form of water or liquid arpound the panel(lens) or the wires and couple it back to is position .
please note before you can carry out this assignment you will have to put off all form of power supply connected to the washer .
thank ou and thanks for using fixya.
Posted on Aug 09, 2010
  • 1,986 Answers
E8 is fault connection from CCU (Control board) to balancing sensor. When you get E8, this is often because of a faulty control board. Try first disconnecting power for a couple of minutes, to reset the appliance. If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
Posted on Nov 17, 2009
  • 10,515 Answers
I am sorry to hear regarding the problem. E8 refers to a fault connection Central Control Unit ( CCU ) to balancing sensor.
The only User Fixable option would be to Unplug the washer for few minutes and then turn it back ON after few minutes. This would Reset the machine.If the problem resolved, that's good unless you need to call professional on site.
Note - More likely it would be a Control Board problem so let a professional on site fix the same for you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Nov 17, 2009
    Thanks for your reply!!
    In different Brand, the same Error Code might refer to different meanings.
    For Eg - In Maytag stack washers, E8 refers to dryer motor run relay.
    The best i could do is to offer a link for Manual . Download and read the same yourself.
    http://laundry.manualsonline.com/manuals...
    Page 30.
    Thanks!!
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
HOW CAN WE FIXED THE E8 ERRUERS ON DAEWOO WASHING MACHING?
·Check motor connection block
Feb 04, 2015 | Daewoo Washing Machines
My daewoo washing keeps displaying E8. what do I do to correct the error
Did you look up your owners manual?
If it is not available, try getting one downloaded from online and reading it there...
Ck
Feb 13, 2011 | Daewoo Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
I have a Daewoo DWD FD1233. It's brand new & 12 minutes before end of cycle it comes up with E8 as an error. The machine wont spin after that. What can i do? Lots of wet washing.
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
Jan 11, 2011 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Daewoo Washer Error E8
Hi.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Nov 22, 2008 | Washing Machines
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
