Question about HP OfficeJet J4580 All-In-One Laser Printer
How can i connect my laptoop to the printer with out a cd drive
  • 4 Answers
You need drivers, either download them from HP official webpage, or if you have a CD copy the driver to HDD of the PC that has one then transfer them via USB to your laptop.
Posted on Nov 17, 2009
Where go I load a cd in my laptoop
need more info. what kind of laptop do you have? some machines, like the chromebooks and mini laptops don't have a cd rom.
Sep 15, 2014 | Samsung Computers & Internet
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I want to install HP deskjet 3940 in my computer
Do the below steps.
1.Connect Printer cable(usb cable)to Computer&Swicth ON the printer.Printer driver cd also put in your cd/vd drive.
2.Start-device&Printers-Add Printer-Add a Local Printer-Select Port as USB001-Next-Have disk-Select yor Cd/dvd drive(Put Printer driver cd in your Cd/dvd drive)-next-next-Finish.
Jun 11, 2011 | HP DeskJet 3940 InkJet Photo Printer
My external firelite model #USBFLB40, stop work today, i tried in other laptoop, and its work but after i disconnect, i want to used it again, and dosent work, ether my lap, nether the other lap... ...
1. It may be due to the electronics in the USB case.
You can purchase a new case and install the hard drive and connect to the USB port to your laptop/PC.
If the drive is not seen after this then the drive itself may be damaged.
If you disconnected the USB drive without "safely removing it in Windows it may have damaged the hard drive controller.
Mar 18, 2011 | SmartDisk FireLite 40 GB Hard Drive
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
I have a S series S6240 and the wireless speed
You need to find a new Driver for the wireless chip
Oct 30, 2009 | Intel S6240 Notebook
No Usb cord, or cd rom drive to connect
Nope...... Get the USB Cord......That's what it requires to connect........
And the cd rom DRIVE is the optical drive (cd/dvd drives are found ON YOUR PC in the front..That's where THE SOFTWARE DISC (that's what you're saying you don't have) goes.
In other words.......get a standard usb printer Cord or get one from another printer........and make sure you got a power cord for it as well... then it'll work..........
And Here's the SOFTWARE FOR IT.... updated.
http://support.lexmark.com/perl/support/support.cgi
Apr 20, 2009 | Lexmark X2600 InkJet Printer
I need to install my printer to my computer but i don can
Try this. Before connecting the printer put the printer driver cd in the drive and install the drivers. If not asked to connect the printer, then restart the computer with the CD in the drive Connect the printer. Printer will be detected.
Dec 17, 2008 | Office Equipment & Supplies
How to re-connect Epson CX 5500 after I changed my hard drive.
If the technician who changed your hard drive was able to transfer ("clone") the system from your old drive, all you need to do is plug your printer/scanner in and it should work. If he was not able to do this and you have a new Windows installation, you need to use the CD that came with the printer to re-install it. Just connect up the printer to the computer BUT DO NOT TURN THE PRINTER ON UNTIL TOLD TO. Start the computer and when Windows has loaded, put the CD in the CD drive. The CD should start the installation process - just follow the instructions. If you do not have a CD, download the necessary installation software from the Epson website.If you don't know how to do this, report back and I will provide more help.
Oct 19, 2008 | Epson Stylus C48 InkJet Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
