Question about Xerox Phaser 4500 Printer
Error message states No Paper In Tray 1 even when there is a full tray. Is this an issue with the tray or the printer? I don't want to purchase a new tray if not necessary. Thanks!
  • 53 Answers
Its the sensor that needs to be replace. Alternatively push the tray back into place firmly
Posted on Nov 30, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
HP Color Laserjet CP2025n Load Paper
In XP, go to settings; control panel; printers& faxes; then left click your printer and select "Properties". Click the "Device Settings" tab and you should be able to figure it out from there, by clicking the trays and selecting "not available". I have that same printer and I just did it with mine so I know it can be done.
Jun 08, 2012 | HP Laserjet Cp2025n Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
No Paper Error
make sure you have an 1/8" gap between your paper and the rear paper stopper in cassette.
hth,
razors
May 27, 2009 | Brother MFC-8860DN Printer
What does "flushing buffer" mean
No response from the original poster as of 6/6/09. Normally, a "Flushing Buffer" message is pointing at a Postscript problem. A quick easy test would be to set the printer for PCL and retry the job. If it works, then you really need to look at the PS print file to find the error. Don
Jan 20, 2009 | Lexmark T644 Laser Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
Hel;p
when I try to print an error message comes stating that I am out of Paper, but the tray is full. Also when the paper feeds it only feeds to the left side of the tray.
Jul 02, 2008 | Epson Stylus Photo R220 InkJet Printer
HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
Once remove both the trays and insert them again and if the problem persists, power cycle and semi-full reset the all-in-one.
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
163 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
