Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Static on all my phones - Westell Wirespeed LiteLine 6100 (B9961001002) Modem
    Guru:
  • 1,738 Answers
Replace your filters, your filters are not filtering out your dsl noise.
Posted on Nov 19, 2009
STATIC IN PHONE WHEN NOT IN USE
Bad or loose connection, do you have static when you use the phone?
Mar 25, 2014 | Panasonic KX-T7130 Corded Phone
Setting static ip address
Do you want to connect your Nokia phone with static ip address you have?You can check the details in user manual or you can search instructions in online.It differ from phone to phone.But you need to wifi modem to connect your ip address to Nokia phone.For home connection ISP provides static ip address.You can use only that.But mobile phone network providers won't give static ip for phone connection.To check ip address you can visit the site Ip-details.com
Jul 24, 2013 | Nokia Cell Phones
I walked across the room to answer cordless phone and static shocked my phone. It does not work now. Why? Can it be fixed?
In a dry climate, and you if you wear a rubber soled shoes, and when you walk on carpet to your cordless phone you will build up a static charge. When as you pick up your phone this static charge will discharge through the phone as you touch it.
The fix, avoid building a static charge by walking around without wearing shoes or move the phone to a location where there is no carpet.
Feb 26, 2011 | Cell Phones
Telephone wiring- phone rings in once -static on line-call out works Seams to be worst after rain or great moisture. Sometimes clears up suddenky
I have the same problem. You might try taking a corded phone to the service box outside where the telephone line connects to your house. On the underneath side there is a line jack used for test purposes. Plug your phone in there to see if static is heard. If you hear no static from this test jack, but do hear static from in the house corded phones, you probably have a wiring issue inside the house. If you hear static from the outside test jack, that's the phone companies problem to fix. Hope this helps.
Aug 31, 2009 | Panasonic Lands Phones
All static on phone
do you have static on any other phones in your house? if so you need to find and clean up the connections in your house (where all the lines come together, with proper connections, not wire nuts or electrical tape) if its just that particular phone, un plug it and plug a phone in that you know dosent have static on it. if theres static, its the jack your plugged into, if not, its the phone.
Apr 11, 2009 | Crosley Cr-91 Country Wall Phone
Static on one handset
If this phone is connected to a phone line, move it to another. If the static goes away, then you know your phone line needs to be replaced.
Also, pop off the back cover and make sure the battery is plugged in securely. If the antenna is threaded, make sure it is snug.
Mar 25, 2009 | Bell Northwestern Phones - 2.4 GHz Digital...
Static in my panasonic telephones
A possible cause for the static in your cordless phones could be dimmer switches around the area of your phone that causes static. Turn the switches completely off (not just turned down) and see if the static leaves. You can replace the dimmers with regular switches if that clears your static. If it does not, another trace for interference: you will have to take a portable radio and turn it to AM 550 mHz and tune it to the loudest crackling noise. Carry the radio around looking for the loudest static interference. Could be a loose connection in a receptacle or panel box. Any small malfunction can cause static on wireless devices.
Nov 21, 2008 | Panasonic KX-TG1033S Cordless Phone
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Static in the ear piece and mic
Sounds like a repair/warranty problem... This is one of the clearest phone's Ive ever had
Dec 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
50 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
