Question about GE Microwave Ovens
GE model JE2160BF03 no power. Blown fuse.
GE model JE2160BF03 microwave no power. Blown internal fuse. What caused this?
  • 612 Answers
They are put out when something metal is put inside and cooked for a few min. They are also put out with power surge. It protects your mag tube. Plus they just go bad sometimes. Could be a number of reasons but these are the most common.
Posted on Nov 17, 2009
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is NOT coming on. I have checked the circuit breaker which is fine. I also disconnected power and conected back
The most likely cause is an internal fuse which has blown. This can be replaced with a fuse of the same volt/ampere rating. Note that a blown internal fuse is most likely due to a fault on the oven's power circuit and further inspection may be neccessary.
Please feel free to contact me for any further assistance.
Best wishes,
Graemevm
Jun 18, 2010 | GE Monogram ZE2160SF Convection /...
Model JE2160BF03 Microwave works but it does not heat.
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 01, 2010 | GE Microwave Ovens
Start button doesn't work for all microwave functions--as well as timer--fuse is ok
Possible causes:
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Dec 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Now power to microwave
Check the AC fuse and the Primary winding of the Low voltage Transformer.
Jun 27, 2009 | GE JE1540 Microwave Oven
Loss od power
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problerm on the control circuit board. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 10, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
745 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
