Question about Philips DVD622 DVD Player
Philips DVD622 Factory reset
I'd posted a query earlier on the factory reset of a DVD622.
I set the dvd to prog scan and the default background is no longer displayed on TV (blueish image of disc center with PHILIPS on disc). Pressing "system" on the remote has no effect.
Is there a manual factory reset for the dvd player and if so could someone give a step by step (idiot's guide) to do this.
Appreciate a response.
  • Raju12 May 18, 2008
    I have searched the site as well as manual. There is no method for factory settings.
    Problem Solver:
  • 25 Answers
Go to and search for your modal then look in Q/A's or just look in the manual for the factory reset....Usually found in the on-screen menu!
Posted on Jan 11, 2008
How to do a factory reset
If it is an internal/external drive for a PC it will not have one. If it is a home entertainment unit it may have a reset to factory default option somewhere in the settings or general sections. If you want an idea of how a particular device can be reset please provide details of make and model and resubmit the query
Jun 04, 2015 | Televison & Video
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
Factory reset of lg 32lc2d
you want to reset all parameters of your TV to Factory default, I assuems and posts this solution.
1. Press the "Adjust" button on the remote handset; press "Up" or "Down" button to select the "Reset" option.
2. Press "Enter " button and Use " >" or "<" button to select "Yes".
3. Press "Enter" button.
All parameters will be set to its original Factory Defaults.
Feb 06, 2012 | LG 32LC2D Television
I was exploring the setup menu and I found an election of Progressive Scan "on" and "off". When I tried "on" then the picture get out and no image was since then. I can't...
There are 2 ways you can reset the player to default factory settings, although I am not sure about progressive scan being reverted back to interlaced output.
1) Unplug the player (or switch off) at power point, as soon as you reconnect (switch on) power to unit, press and hold the [STANDBY-ON] button (on the front). As soon as you see 'IS TV ON?' on the front panel display, release the [STANDBY-ON] button. This should reset it.
- OR -
2) If you do not have the instruction manual, you can download a free pdf of it;
I hope this helps a tiny bit.
Mar 17, 2011 | Philips DVDR615 DVD Player
How do i reset my d-link dir-615 to factory settings
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link DIR-615 Wireless Router
My PHILIPS 34PT9420 tunes only fifty channels and not more than that.Earlier it use to tune 99 channels.So kindly tell me how to tune all 99 channels or how i may have changed some of its factory settings...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 23, 2017 | Philips 34PW8502 34" TV
Cant turn off progressive scan
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
Aug 24, 2008 | Philips DVD 622 DVD Player
No video in my philips dvd622
Check if you have not accidentlychanged to progressive mode which can cause this proble.
Are you connected to TV using Composite video out?Try connecting using S-Video or DVd (component inputs).
Do provide feedback and rate this solution.
Mar 26, 2008 | Philips DVD622 DVD Player
Philips DVD622
reset 1.hit the menu button on the remote play with the options there you will find it its a common task on these dvds!
to go region free it
2. hit 2812 ok until you get 9
4. shutt off then reopen it
it should be region free i am not shure if it needs to be repeated!
Jan 09, 2008 | Philips DVD622 DVD Player
Philips dvd player model dvp 3110k
Im assuming you're looking to restore to default settings.
I couldnt find your exact model, so i got one as close as i could. On page 38 of this manual, there are instructions on how to restore to original settings. Try it out, and report back >.<
Jan 04, 2008 | Audio Players & Recorders
Philips DVD622 DVD Player Logo
702 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
