Question about Jacuzzi Cetra Whirlpool Bath LH WHITE H525959
Back jet near front panels leaks, what part do i
The back jet near front panels leaks, what part do i need to replace?
    Scholar:
  • 35 Answers
You may not need to replace any parts. If it is leaking around the seal (which I have had happen on occassion), a high quality silicone adhesive should be applied. However, it is best to unscrew the jet at the connection so as to get good coverage. Just applying the adhesive around the connection without getting it between the unfinished portion of your tub, is just asking for future problems.
Posted on Nov 19, 2009
The Front Door Came off of my Bosch WFL 2060 when a huge container of detergent fell on it while open. I think I need a new Rear Door Panel, Gray, Wfl 2060/WFR 2460 because the old one is damaged, but I...
I have same problem. Washer vibrated badly during spin cycle and door subsequently came off because back panel..Mfr. # 00432074 cracked near hinge. Looks to me like hinge must first be inserted before panel replaced. I do not have proper tool either.
Sep 29, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Coffee machine leaking at front when making coffee, seems like jets blocked and coffee coming from behind, have tried de calc and clean but no better. how do i get behind the front panel to the pipes??
You say it is dropped on the front side of the tv but how come it come from the back of the tv. It must be spreaded. While coming to the back side hope it didnt damaged vital elements of the tv. Anyway don't open it until you clean the internal organs. Later need to be opened under the supervision of a technical person.
Nov 05, 2012 | Televison & Video
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a Matag model A482 that is leaking water when filling for wash or rinse and I want to know how to remove the top (no manual...); it seems that there is a release mechanism in the front of the...
you will have to first remove the front of the machine two screws at the bottom of the front pannel tip away from the machine to release the front tabs. you will then find screws run up into the top remove these and the top will tilt back locate the filler tube from the valve and follow to the inlet to the washer about half way there should be a vacum cylender inside a rubber tube that has probably become loaded with hard water deposits or just stiff from age replace the tube and leaking should stop
Mar 01, 2011 | Washing Machines
How does front panel come off (safely) to swap out door switch on kenmore washing machine 41744152400
The front panel does not need to be removed when replacing the door switch. What needs to be removed is the door gasket. Open the washer door. Get a pair of needle nose pliers then look for the retaining hoop securing the door gasket to the lip of the door opening. Stretch the hoop retaining spring at the bottom of the lip of the door opening then carefully pull the hoop out. Make sure not to tear the door gasket or else water will leak through it.
Remove the two screws securing the door switch to the front panel. Peel off the door gasket near the door switch then pull the door switch off the front panel and out of the washer.
Disconnect the wires from the door switch terminals then connect it to the new door switch. Secure the new door switch back to the front panel then put the door gasket back over the lip of the door opening. Properly secure the door gasket to the lip of the door opening with the retaining hoop.
Mar 11, 2010 | Frigidaire ATF6000ES Front Load Washer
How do you remove front panel to locate leak?GE Profile WPRE6100G
I believe you need to pry up slightly on the top and reach through the gap with a small screwdriver and press on the clips on either side to release the top and lift the top. Then there are two screws that hold the front to the sides and you should be able to lift the front off. Good luck.
Mar 07, 2010 | GE Profile WPRE6100G Top Load Washer
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Leaking inside washer, how and which panel do I take off
You will need yo remove front panel. Should be 2 screws near bottom on front. Take these out. Use putty knife or thin screwdriver to pop clips to pop the top up. the 2 clips are in the slot between the top and the front panel. Once top is up you will push down on the front panel. There are 2 tabs and slots on each side that connect the front panel to main cabinet. As you push the front panel down you should be able to pull the panel toward you and out. The tabs and slots are easy to bend and sometimes hard to get back in. Hope this helps!
Jun 03, 2009 | Frigidaire Washing Machines
Kenmore Frigidare Front load dryer 417.93042203
The front panel clips usually hold by friction. Just pull gently on the upper corners and it should hinge down.
Aug 08, 2008 | Kenmore 73952 Gas Dryer
Jacuzzi Cetra Whirlpool Bath LH WHITE H525959 Logo
123 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
