Question about Eddie Bauer 22-625-BLD
HOW DO U STAP A CAR SEAT - Eddie Bauer 22-625-BLD
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Go to your nearest Halfords or local independent nursery shop
Posted on Nov 18, 2009
Locked keys in the, car battery dead and cant use the keyless entry
you can use flat metal stap cut hook into it bend to kinda contour the door where key lock is play arund you will open it no coat hanger flat thin thin metal strap
Mar 15, 2013 | 2006 Lincoln Zephyr
Antifreeze go over boll when motor is hot
remove the cap on the bottle, check on the inside of the cap if the o'ring is not damaged.buy a new one
Jul 09, 2012 | 1995 Volkswagen Passat
My nokia 7210 supernova has a problem in its radio.. radio does not work.. it shows not enough memory. how can i solve this problem?
phone memory has limited space.if phone memory is about to full.this type of problem occur.you should move some item from phone memory to memory card.after that go to music menu.selects options>update library.after updating press ok.your problem will be solved.
Nov 15, 2010 | Nokia 7210
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
My 2002 Chrysler Town and country has a built in child restraint seat in one of the rear captian chairs how do I adjust it?
I have the same seats. All you have to do is pull the small teather stap at the top of the child booster seat. You pull it to make it tighter around the child or you pull it and then pull the child saftey straps at the same time. You also do not have to purchase the manual if you call chrysler they will send you one for free. That is how I got mine.
Jan 17, 2009 | 2002 Chrysler Town & Country
Jane powertrack 360
There should be two black triangular attachments with little red handles that go on to the sides of the buggy. You use the grey handles at the end of the side arm of the buggy to pull the rear locking pins backwards and then slot the attachments on to the front pin with the red handle pointing forwards. Release the grey handle and it will lock into place. When both sides are in place, simply drop the car seat on to top of the two attachments. Removal of the car seat is by using the red handles.
HTH..
Nov 10, 2008 | Jane Powertwin Jogger
FORMATTING A PC
hi frined
click here to stap by stap information
Apr 07, 2008 | Computers & Internet
Eddie Bauer 22-625-BLD Logo
85 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
