Question about Kenmore Washing Machines
Machine empties water of the wash and rinse cycles all over the floor-no crack in the drain pipe - no sign of leakage in the drain hose attatched to the washer
    Master:
    Sergeant:
  • 447 Answers
I don,t think its the pump it sounds more like a split or loose hose from the main tub, only way to tell is to check it while its runing
Posted on Dec 21, 2011
  • 612 Answers
Most likely have a bad water pump. If not you have a bad tub seal. Just hope it's the water pump. It's located just under the front. It's white and has either 2 or 3 hoses coming from it. Some models have 2 some have 3. No problem to replace and cost around $40.00. Good luck
Posted on Nov 17, 2009
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
Washer does not spin for rinse cycle water does not drain
Check the end of your drain hose that attatches to the pipe under your sink to see if there is a block. The washer will not spin if it cannot empty the water before hand. Also check to see if your coin trap has any items in it as this will also stop the draining cycle. This is normally located at the base of the appliance just infront of the pump
Hope this helps
Mar 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Washing machine leaks from underneath after rinse cycle...wash cycle runs fine, but when it drains out after rinse cycle, it leaks from underneath
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Jul 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine keeps draining on the rinse cycle.
your drain hose is either stuck to far down in the drain pipe or your drain hose is sealed to the point it has no way air can enter the drain pipe which creates a siphining issue. your drain hose has to have a air gap so the siphing can not occur. the end of your drain hose should be no lower than 34 inches from the floor draped into the drain pipe with a way air can enter at that piont.
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Jan 31, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
