Question about Bosch Dishwashers
I am a builder. I installed my Bosch dishwasher.
I am a builder. I installed my Bosch dishwasher. We are leaving our home in ME for the winter and I would like to winterize my dishwasher myself as I am tech savy. What do you recommend?
    President:
  • 704 Answers
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Posted on Nov 17, 2009
On Bosch dishwashers it is better to remove the inlet valve entirely (located at the bottom of the unit where the water intake line joins the dishwasher, usually requires a 7/8 wrench) and reinstalling it in the spring when you return. I've had to replace my inlet valve twice due inproper winterization proceedures even though I poured over a litre of RV anti-freeze and turned on the unit to distribute the anti-freeze it still was not enough.
Posted on Apr 24, 2010
Bosch dishwasher won't drain and leaves film
You may have to use a rinse aid to get good results.
Jan 30, 2017 | Bosch Dishwashers
Where do i locate a Bosch Nit615c induction hob service manual
Is this what you need
http://www.bosch-home.co.uk/our-products/builders-developers/hobs/NCT615C01.html?source=browse
Apr 28, 2014 | Dell M782 Monitor
WHERE CAN I GET A BOSCH DISHWASHER THAT IS 22'' WIDE
I don't know where you live and please do not say. I reviewed the entire Bosch dishwasher lineup and found 2 machines that were 18 inches. You asked for 22 inches. It appears that Bosch doesn't currently make such a thing. Please have a look here: http://www.bosch-home.com/us/products/dishwashers/dishwashers/custom-panel/list.html
If you are sure they make such a thing, I suggest you click on the Contact Us tab, select At Home and dishwashers where you will find this information:
Address BSH Home Appliances
5551 McFadden Ave.
Huntington Beach, CA 92649 Tel 1-800-944-2904 Fax 714-901-5360 Internet blue_arrow.gif Contact us
I think this is the US version - there may be a different link if you are not in the US - Please search within the Bosch web sire for your country for best results.
Thank you for your quesiton today.
Mar 03, 2011 | Dishwashers
My Bosch dishwasher was not installed with an "
From an internet posting ::
The purpose of the air gap is too prevent back-flow and siphoning, and newer dishwashers (past 20 + years) have back flow preventers built in and looping the drain hose (not a circle, but an upside down u to the top of the cabinet or behind/side of dishwasher) prevents siphoning. Aside form being ugly space wasters the cheap air gaps have a tendency to spit and cough water out.
Read more: What is the purpose of an 'air gap' for dishwashers? ' Answerbag http://www.answerbag.com/q_view/92208#ixzz1ACnxhxz3
Jan 05, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch dishwasher has a terrible from day one. I have tried running vinegar through a wash cycle. My dealer I need to run it a few times. I have had this machine for well over a year and still gives...
Hello and welcome to Fixya.
It "smells" ( just kidding ) like you might have a problem with the way your drain hose is connected by your description.
It is crucial that your Bosch dishwasher have a siphon break or "hi-loop" installed in the drainage between the dishwasher and where it enter's your homes plumbing.
If it does not you can try different cleaners until the cows come home with little effect because the odor is coming from the drain line itself.
Was this unit installed by yourself or someone you know ? Or was it installed by a plumber/professional installer.
In the end it actually makes little difference, I'm just curious. I see professional installers as well as plumbers fail to include this crucial feature over and over.
Let me know. I'll watch for your post. If you are unclear as to what I'm referring to, check your installation guide that comes with all Bosch dishwasher's.
If you do not have any instructions regarding the proper drain/install I can email you a copy, but I would need your email address.
Good luck.
macmarkus :)
Jun 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
NEED INSTALLATION INSTRUCTIONS
Hi if you visit this site you will be able to find instructions and manuals that you can download for your appliance
Jul 25, 2009 | Bosch Evolution 500 SHE55M05UC Stainless...
Need installation instructions for a Bosch dishwasher with hidden controls, possibly SHX36L 12UC 24-in under counter dishwasher. It comes to me used with no instructions and the usual install makes it...
go to thermador.com to view manuals. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Oct 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher problems
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Mar 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
1,011 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
