Question about American Standard AMERICAN STD 12 RGH Champion 4 Tank WHITE
Gasket and oring replacement. I'm on my third try. Still keeps leaking. Tank #4266. Worked well for about 4 months. Started to leak. Called American Standard. They sent a new gasket and oring. Worked well for about 3 weeks. Called again, sent me 2 new set of gaskets and orings. Still leaking. I need to know how to install the parts, as I must be doing something wrong.
  • 4 Answers
Had a problem with water level dropping in tank causing toilet to refill a few times a day. The problem was the round rubber flapper had a few bumps along the sealing lip, I removed rubber seal and laid it flat on workbench and took a new razor blade to shave these 2 bumps off and as soon as the blade touched them they popped and water came out of them then they laid flat. Somehow they were water blisters in the rubber keeping the flapper from laying completely flat causing water to leak into bowl. It seemed fine and flexible otherwise so I reinstalled it and so far so good. I also feel better knowing I can just change this rubber ring as it pulls off of plastic plunger in case I need to change it. Hope this helps.
Posted on Jul 19, 2012
  • 20 Answers
R u using any glue to seal the gasket and oring
Posted on Nov 17, 2009
Testimonial: "Using the glue seems to be a good idea, but American Standard does not mention it. There was no glue on the original parts."
    Brigadier General:
  • 4,088 Answers
I assume that you are talking about the tank to bowl seal that is leaking--these do not require any kind of sealer. Inspect both mating faces to be sure there are no porcelain defects causing this problem. Take the water spigot/flapper seat out of the tank. If there is no gasket along the tank side, get some 'plumber's putty', make a rope of it, and wind it around the spigot just under the flapper seal area and reinstall it. There should be a rubber washer on the head of each attaching bolt (and the bolt head goes in the tank side) and the large sponge rubber 'o' ring that seals the water joint with the bowl. If the 'o' ring is cone shaped, put the wide end to the tank. If the tank is being used as a backrest by the user(s), you may need to hot-glue a wood backer behind the tank to prevent it from being pushed backwards.Don't pull the two bolts down excessively tight--just tight enough to eliminate obvious rocking.
Posted on Nov 18, 2009
Dishwasher Leaks
Find a new repair person
Apr 07, 2017 | LG LDF7932ST Dishwasher
M 7030 kubota tractor fuel leak from screw on bottom of tank
did you use a generic oring to fix it last time and not one rated for fuel?
May 21, 2012 | Garden
Air leaks when triggered and no nail
Make sure no nails in gun. With air connected listen for leaking thru nose of the gun also. If leaking thru nose slightly, air is getting past the cylinder seal oring and/or top of cyl is not seating against headvalve. Repair leak to nose of gun before trying to fix head leak. With no air leaking thru nose of gun, add plenty of white grease to orings in the head (one oring at a time) to see if leak is less and/or grease will streak behind the leaking oring. Then repair as needed. May need slightly thicker oring or sand surface where oring makes contact to remove scratches that are allowing air to pass. Also air can enter the head thru the small port in the gasket leading to the head (make sure that the gasket is sealing).
Nov 05, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
I have an air leak, where can I purchase a gasket set for my framing nailer
Best place for parts is www.toolpartsdirect.com. They do not sell a gasket kit. The parts are listed individually. oring kits are available on ebay for about 20.dollars. Use key search "hitachi oring kit". If you have question about your leak and specific cause of leak post again with exact area of leak. Good luck with your repair
May 30, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
My gun is leaking air from the front of the reservoir adapter plug. I've replaced and lubed the Orings on it, but the thing still leaks out a lot of gas. Any ideas to why?
You could try to by a tube of "Gasket Maker" gel and use that on the orings? Or even just replace the orings. could be worn.
Feb 13, 2011 | Paintball Spyder MR2
My son replaced the thermostat and thermostat housing on his 2002 ford taurus. It is leaking from the bottom of the housing. What would cause this?
COULD HAVE DAMAGED RUBBER O RING TIGHTEN TOO TIGHT OR REUSED THE OLD ORING WILL CAUSE LEAKING.IF YOUR THERMOSTAT HAS PAPER GASKET INSTEAD O RING. YOU NEED TO PUT SEALANT ON BOTH SIDES OF THE GASKET.THAT WILL KEEP IT FROM LEAKING.IF YOUR VECHICLE HAD A RUBBER O RING AROUND THERMOSTAT REPLACE WITH NEW O RING DONT PUT PAPER GASKET IF YOU HAVE THE O RING SEAL.THE O RING DOES THE SEALING NO NEED PAPER GASKET.
Jan 13, 2011 | 2002 Ford Taurus
Leaks
Hello, The coffee maker has 2 places where it is common to have a leak. Unplug the machine then take the lid off. Next using a coin remove the bolt holding the fill pan to the tank (it's the nut on the inlet to the tank) once this fill pan is out you will see the top of the tank. Here is the first spot it can leak around the tank lid gasket. You will normally see evidence of water leaking. The second place if you look at the top of the tank is the tube running from the tank to the basket, this has a gasket that commonly goes bad. Find which gasket is leaking and replace it. If you are buying your coffee from a local coffee company they will normally repair the machine for you even if you own the machine. if not you can either get the new gaskets by calling Bunn or from a company in California called holiday house. You could also try getting the part from a local coffee company but they will try to send a sales guy out with the part :) Hope this helps! If you have any other questions please feel free to comment. Mike
Dec 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Leaking rusty water
Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
Gasket is about 2 bucks available from Bissell.
Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
American Standard AMERICAN STD 12 RGH Champion 4 Tank WHITE Logo
740 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
