Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Ultimate care 2 wont drain or high spin. does agitate ok
It will fill and agitate, but wont drain and high spin, can hear an audible click near switches, will continue to click for a couple minutes then stops and timer wont move any further.
  • 125 Answers
Try pushing down on the lid, if the machine starts to drain and spin you need to adjust the hinge on the lt side. To do this you need to take the screws most of the way out on the back of the control panel ( on the end caps). Then remove the spring clamps that hold the cabinet onto the base. Use a screwdriver into the front of the clamp and press to the back of the machine, then unhook the connector for the lid switch. Pull the cabinet forward and you will be able to see the hinge, use a channel lock or pliers to bend the end of the hinge towards the back of the machine, the lid will need to be open to adjust the hinge. it will only take a small adjustment. After adjusting shut the lid and listen for the click to see if it was enough. Hope this helps
Posted on Jan 10, 2008
No spin
check the lid switch,close the lid and then open it a few inches close and open it a few times like this,you should hear a clicking sound when you do this,if you don't the lid switch is bad,common problem,
Jun 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have an whirlpool ultimate care II Imperial Series Model # LSN2000JQ2 Serial:CM2819491 Type: III That will fill but won't agitate. Is this something I can really fix on my own?
Could be a problem with the lid switch or motor coupling. Does it drain? Does it spin?
when its time to agitate or spin, do you hear the motor?
Lets start with the lid switch. open the lid and use a screw driver to push the switch down. pay attention to see if you hear it click. Try to run the unit with the screw driver holding down the switch.
Let me know what happens so I can further assist you.
Feb 20, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer not spinning
If you are neither spinning nor agitating and you can hear the motor running (humming or buzzing) the the problem is with the coupling. See the first link below to repair.
If the motor does not run, only fills, no drain, no buzz no hum then the problem is most likely with the lid switch, see the second link.There is video near the bottom of that page showing how to replace it. Let me know if this helps.
Coupling
Lid Switch
May 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont agitate
your dog ears are bad.
You can replace them for about $10 @ your local appliance store.
Aug 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont agitate or spin
lift the lid up and down a few times , just before it closes you should hear it "click", if not its not recongnizing the door being closed ,
check the left hand hinge assy make sure the screw s on the side are real tight , play in th ehinge might be an issue
Mar 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Tub will fill the machine will agitate but when time to drain nothing happens
you need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch p#3949247(if that vcorrect mod num lsq9564j
Feb 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
