Question about Lexmark X4270 All-In-One InkJet Printer
I need to know how to get to the ink cartridges on
I need to know where the ink cartridges are located on a lexmark x4270 and how to grt to them.
  • 100 Answers
  1. Make sure the All-In-One is on.
  2. Pull the control panel toward you, and then open the cartridge access door
The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy.
  1. Pull the old cartridges toward you, and then lift them out. Store them in an air tight container or dispose of them.
If you are installing new cartridges, remove the sticker and transparent tape from the bottom of the cartridges.
Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
Push back firmly on the cartridges until they snap securely into place.
Close the cartridge access door, and then close the control panel.
  1. Use the buttons on the control panel to answer the questions that appear on the display:
  2. If the color cartridge you installed is new (it has never been used), press Select.
If it is old (it has been used), press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the color cartridge you are using, press Select.
If it is not the number of the color cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. If the black cartridge you installed is new, press Select.
If it is old, press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the black cartridge you are using, press Select.
If it is not the number of the black cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. Continue with Aligning the print cartridges to ensure proper installation.
Note: You can also use the Lexmark Solution Center to install the print cartridges
  • Click Start oI need to know how to get to the ink cartridges on - onestep.gif class= Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution CeI need to know how to get to the ink cartridges on - lsc.jpg>.
  • From the All-In-One Center, click the Maintain/Troubleshoot tab, and then click on a topic.
    Here is the manual
    Hope that helps you :)
Posted on Nov 17, 2009
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
My LEXMARK x4270 won't print. I replaced both ink cartridges and when I tried to print or copy, the paper comes out blank.
Did yo remember to remove the protective tape from the cartridges. Are the cartridges in their correct locations and are they firmly seated in their receptacles?
Jan 23, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do you know and find the cartridge number in a x 4270 lexmark printer?
The Lexmark X4270 printer uses cartridge number 70, 71 and 75 for the Mono Ink Cartridge. For the Color Ink Cartridge it uses 19,20 and 25. You can check this link - http://bit.ly/d2bbwm if you want to purchase these cartridges. Thanks.
Aug 15, 2010 | Lexmark X4270 All-in-One Multifunction...
Ive a lexmark x4270 tried to copy says consult user guide for error #1203 and i dont have a users guide. anyone know what i need?
The error #1203 on the Lexmark X4270 indicates a problem with one of the ink cartridges. You can try to check this link - http://bit.ly/ckmSbC - for the steps that will help you resolve the problem. If it still the small I would suggest contacting Lexmark Technical Support. Thanks.
Aug 08, 2010 | Lexmark X4270 All-In-One InkJet Printer
I found the ink cartridge. I just need to know
Perhaps the Lexmark X4270 User's Guide will be able to assist you. To download, click on this link: http://bit.ly/cNbUKo . Go to Maintaining your All-in-One for the instructions on replacing the print cartridges. Hope this helps.
Jul 15, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270- Can't find manual. Shows error 1203. How can I correct this. Thanks
Hi
Error 1203 occurs due to smearing of ink on the carriage bottom where the cartridge head touches the carriage bottom. Please turn off your printer and unplug it.
Clean the bottom of carriage with a damp cloth and clean any dried ink. Make sure that you use the printer after 5-10 mins or until the carriage area dries up completely.
If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
Now try and check whether you are still getting an error. I hope that you are using orignal Lexmark ink. If not then please use genuine inks only.
Daniel Scott
Jun 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Where is the ink cartage on a lexmark x4270 fax
Here's an article in the Lexmark website to guide you on how to change/replace the ink cartridges on your Lexmark X4270 printer. Just click on this link: http://bit.ly/bR8WEN. Hope this helps. If you need more assistance, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark X4270 fax machine, and I have just got a new black ink cartridge. The old one was a lexmark 71 the man at Quill said to get a lexmark 75 hi-yield. so I did my machine keeps saying black...
Did Quill sell you a "OEM" (Original Manufacturer's Equipment) or a cartridge a third party cartridge?
If it is a third party ink or cartridge, then that's your problem. Lexmark does not condone the use of third party ink or cartridges. This is considered to be product tampering by Lexmark and they will void the printer warranty if damage results from the use of these type cartridges.
I do apologize for the bad news, but I do ask that you do not shoot the messenger. :-)
Jul 03, 2009 | Lexmark X4270 Printer
Lexmark X4270 All-In-One InkJet Printer Logo
95 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
