Question about Miele Dishwashers
The filter bit at the bottom of the dishwasher, what does it look like? I need to know if i am missing a part?
    President:
  • 1,653 Answers
To remove the filter
Turn the handle anti-clockwise to release the filter combination - 1
a. Lift the filter combination out of the dishwasher - 2
b. Remove any coarse particles and rinse the filter well under running water. Use a nylon brush if necessary.
To clean the inside of the filter, the flap must be opened:
^ Press together the catches in the direction of the arrows -1 as shown,
and open the filter -2 .
^ Rinse all the filters under running water.
^ Then close the flap so that the catch engages.
Posted on Nov 17, 2009
Should there be a little water left in the dishwasher
yeah there should be a bit but the bottom should also have dishwasher salt in there. this is the bottom. the salt helps kill smells also helps cleaning. when you bought the dishwasher it should of come with a funnel thats for filling the salt into the system.
Jun 08, 2017 | Frigidaire FGHD2433K 24 in Builtin...
After washing, water does not drain at bottom of dishwasher. turned on for a few seconds and off and still will not drain
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 12, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
There isabout 2 inches of water left in the bottom of the dishwasher after i run a cycle , and some food bits left in the water how do i drain the waterand remove the food bits? A manual was never left...
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | GE Dishwashers
Hi, I have an ASKO D3250 dishwasher and it keeps stopping during the wash cycle and flashing the heavy pots and pots symbol simultaneously. I tried cleaning the filter basket and found a little plastic...
The part is a cap for the drain pump. You can put it back into position by removing the filters and placing it to the left of where the circular filter would be positioned. The part goes in with the part numbers on the bottom facing down. When positioned it should not interfere with the threads for the circular filter. You may have to scoop out the water in the bottom, to have a better look at how it is positioned. It is always normal to have a little bit of water in the bottom filter area (below the silver screen filter).
Oct 18, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Possible obstruction in drain area
The spray arm will just pull up with a bit of resistance then turn retainer anti-clocwise and pull out filter then check for debris and clean all fine mesh filter screens.But it may be that the debris has got into the pump and caused damage.
Hope this helps.
May 14, 2010 | Electrolux EDW5505SS Dishwasher
Dishes on top rack do not come out clean. Bottom rack O.K.
Have you tried cleaning the filter? We had a similar problem. The repair man came and removed all the spinners and the other stuff at the bottom above the motor to get to the filter. It was blocked with all kinds of old food bits and pieces, the odd bit of plastic film etc. He cleaned it, replaced it and we havn't had a problem since but he said it needs to be done about every two years. It can be done by someone who has reasonable DYI skills.
Jan 04, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
Lower arm and filter assem kenmore 587.16152400
The filter needs to go back on first, then the arm has notches so that it'll tight down, you need to rotate the arm till it falls in place, then the white handle is used (Goes around base of arm) to tighten it into place.
Oct 19, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
608 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
