My samsung tv takes about 15 minutes to come on
  • 610 Answers
Usually means the power supply board is starting to fail, 1-800-samsung to find nearest service center.
Posted on Nov 17, 2009
Testimonial: "thanks 4 your help"
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Samsung DVD Remote contol: Cannot change over from TV to DVD. DVD Receiver/TV button remains on TV.
Hello, take the batterys out wait 15 minutes and put it back it will work if not change the batteries.
success!
Apr 03, 2011 | Samsung Televison & Video
Samsung TV turns itself off every 10/15 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
I have a Samsung led, high definition (1080i) bvd, srs tv, after about 10 or 15 minutes the screen goes blank but you can still hear the sound, if you turn it off and on it will work for around 15 minutes...
Hi, i have the same problem but not always at 15 minutes, sometime longer and sometime shorter. However it is the same symptom. I put a table fan right at the lower back of the TV and blow it upward at about 45 degree to make sure the air blow inside of the TV as much as possible. I used this way for a month and haven't had any black out problem. The only thing that you have to live with is your fan's noice. Good luck to your.
Jul 19, 2010 | Samsung Televison & Video
Samsung HCM4215W,shuts off.
Sounds like a short in the power wire, it takes about 10 to 15 minutes to warm up then shorts out and when it cools down you can watch for 10 to 15 more minutes before it shuts off again, you need to take it in and have the powercord replaced because this is very hard to do from home and one mistake can make the whole tv not work.
Feb 27, 2008 | Samsung HCM4215W 42" Rear Projection...
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung PCK5315RX TV turns off
you tv problem is intermittent have a tech resolder you tv circuit.also have him check the power supply you could be having problem with the component there.probably the regulator diode or cap.good luck
Aug 01, 2007 | Samsung PCK5315RX TV
Horiz sync
take the tv to a tech the tv is haqving a problem in the power and the horizontal circuit.you can get a schematic from www.samsphotofact.com
Apr 03, 2007 | Samsung TSK2792F 27" TV
jasbo
jasbo
