We lost power the other night when it cam on there was no power to my cable box or tv the outlets still work because i plugged something else in them is there a reset button on the tv
    President:
  • 1,284 Answers
Is the TV connected directly to the outlet in the wall or through a power outlet on the cable box? If so connect the TV directly to the wall and see at least if it does power up. If it does than the cable box is bad and will need to be replaced. If neither the cable box or TV power up when connected directly to the outlet then the possibility is you had a power surge that damaged both.
Posted on Nov 17, 2009
My magnavox crt is about 10+, worked great.Last night,the screen remained black, and sound was static. Tried unplugging, held the power button, ran a new cable line from working tv.No lights in back.
I hope I can help. I would first try another outlet.
  1. another power outlet
  2. check the cable from the TV to the wall or cable box
  3. Check the TV Input channel, make sure you go through each source input to verify which tv/video input is the correct one.
Jul 28, 2016 | Televison & Video
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a panasonic TH-C42HD18. Last night a fuse in my fuse box flipped so I lost power to the tv. I reset the fuse (in the fuse box) but now My tv will not turn on. Everything else plugged in to that...
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
Jun 02, 2011 | Panasonic TH-C42HD18 42 in. Plasma TV
I bought LCD TV 32"
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Apr 03, 2011 | Televison & Video
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Had the digital cable box installed yesterday. The tv worked
The cable box has an AC outlet on the back of it and sometimes the installer plugs the TV power cord into it. This outlet has two modes--IE: on all the time or switched. If the outlet happens to be programmed to the switched mode, the cable box has to be on before you can turn on the TV. If the outlet is on all the time, then you can turn the TV on at will. So, you have to decide if the TV is plugged in there or it is plugged into the wall recptacle. If none of this explanation fits, then we need more information.
Jan 07, 2009 | Hitachi 46UX24B/25K 46" Rear Projection...
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
