How to fix my damaged USB storage
Is there any program or software that could fix damaged USB or flash drive storage?
  • Anonymous Aug 01, 2008
    my usb storage shows code 10
  • 2,427 Answers
Well you can download HP FORMAT UTILITY aviable from the hp site and try to format it. and if that dont work well you may need to get a new one ...
with flash drives there isnt anything much you can do
Posted on Jan 10, 2008
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
Dec 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4 gb pendrive is write protected .how can i remove the write protection
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage the firmware, data can be saved
2. Damage the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and repair the firmware.
Nov 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Removing write-protectiion
1. Damage to the firmware, data can be saved
2. Damage to the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and firmware repair.
Oct 24, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i connect transcend jf v30 16 gb pen drive it takes lot of time and computer doesnot respond and it displays as unreadable format or corrpted
There are three possible
3. Bad sector
Oct 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a JF V33 Transcend USB and I tryed JFSW and JFSW2 to try to reformat the USB but, they both cant read the USB I need help ASAP plzzz
There are two possible
My flashdrive won't respond at all. I think that it was somehow disconnected on the inside, but I have no way of knowing. Is there any way that I can retrieve the data or fix the flashdrive?
you can try some data recovery software. You can see
http://www.asoftech.com/articles/undelete-files-from-usb-drive.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the flash drive (use quick format), and then use above mentioned software to scan again the flash drive and recover your files.
Sep 05, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My 2gb micro sd which was in my blackberry isnt working, all my pics and videos are gone and when i put it into computer it says that the file system is raw and that the card is 1365gb it wont let me...
Hi
You do not say which operating system your computer is running.
Unfortunately read/write errors sometimes occur on these type of storage devices.
They are susceptible to water damage, shock damage, magnetism damage, static electricity damage, heat damage and physical damage.
There appears to have been some form of corruption that has affected the file format. Part of the storage area is not being seen by your operating system.
Hard disk management software such as Paragon Hard Drive Manager might enable you to make a copy of the data in the storage space that is not currently showing and then attempt to open the copy.
You can use Windows Software compatibility Manager to download software that converts raw files to other file formats that your computer can read.
Linux Diagnostics tools can often be effective in recovering lost data where windows based software fails.
Important data stored on ultra portable storage devices should always be backed up.
Try different Recovery Software (www.softpedia.com is a good source). Different programs can have different success rates.
Here are some to consider:
Active File Recovery
Card Recovery
GetDataBack for FAT
O&O DiskRecovery
Smart Flash Recovery
Recover My Files
I hope this helps.
Good luck.
If my answer helps you, please take the time to rate it. This helps answerers to better understand the asker's point of view and helps us explore ways to provide and maintain high quality answers.
Thanks for using FixYa.
Aug 30, 2011 | SanDisk 2GB microSD Memory Card
(11762) LS-120 (SuperDisk) Storage Media: I have an older USB LS120 Drive and need the drive...
Download the software for drivers at
www.driverrobot.com
Use the following activation code :
DACG-KCCJ-AEB2-P52W-TATA
Run a scan with the software and install all the drivers you need.
Enjoy
May 18, 2010 | Imation (11762) LS-120 (SuperDisk) Storage...
Computers & Internet Logo
82 people viewed this question
Alun Cox
David Payne
David Payne
