Question about Quinny ZAPP Stroller
Is it possible to get a replacement back wheel?
  • 92 Answers
Best chance would be to contact Quinny themselves. Failing that buy a cheap second hand one and replace the wheel yourself...Hope this helps
Posted on Nov 17, 2009
My 99 accord ex is still making a squeaking noise when turning right sounds like metal hitting metal just replaced axle on that side passenger.
Have you inspected the brakes for wear? Possible backing plate rubbing on rotor. Possible wheel bearing on that side. Was the axle nut torqued to spec? This nut keeps proper pressure on the wheel bearing.
Sep 06, 2015 | Cars & Trucks
2001 ford escape xlt..been leaking brake fluid out inner back tire.now I have no brakes...they r drum in back.what will I need to replace
the wheel cyliners need to be replaced ,that is most likely where it is leaking , recommend bleeding the brake system both front and rear after changing the rear wheel cylinders
Aug 15, 2015 | Ford Cars & Trucks
My car is leaking brake fluid from the drivers side back tire. we've already fixed the wheel cylinder and the brake pads are good what is the problem
You'll have to go back under with some rags and wipe everything down so that it is dry. Then have someone push the brake pedal. You should be able to see where the fluid is coming from. It's most likely either the line is not completely tight in the wheel cylinder or the bleeder screw isn't tight enough. It's also possible that you may have cracked the steel brake line while you were doing your work. That will have to be replaced. Measure the length back to the junction block and the diameter od the line and you can pick up a pre-made onr at the auto parts store. Don't forget to get brake fluid while you're there. There is also a possibility that the wheel cylinder itself is leaking inside the wheel. They will sometimes leak out the ends and will have to be replaced. Hope this helps.
Jan 23, 2011 | 2000 Mercury Sable
All Wheel Drive Disabled
I would take it back to place where it was repaired, it is possible that the part they replace is defective..
Also they should have clear all codes in the system at that time!!!
Jan 03, 2010 | 2005 Chevrolet Uplander
I bought Phil and Ted 2 weeks ago since than the left back tire has been punctured twice
You may have something stuck between the innertube and the wheel mould possibly, or the wheel mould may have a sharp piece inside. Alternatively, the wheel may be under or over inflated.
I would suggest that you either take this back to the retailer for inspection, or take the wheel to a bicycle shop so that they can replace the innertube for you.
I hope this helps.
Oct 08, 2009 | Baby Gear
Replacement back wheels for Maclaren Quest Buggy
yes replaceable with expert help on change them, about £ 22 for a set of 4 for back wheels. a child safety is an issue here, do seek expect help fitting them. Fitting them wrong could mean wheel falling out when crossing roads and no brakes on slopes!
but I am sure the purchaser is buying them on " as it is condition" no? just give them the address below they can help!
PRAMS 'N' THINGS
108 St Mary's Road
Market Harborough
Leicestershire
LE16 7DX
Opening Times
Tues - Sat 9.30am - 5.15pm
Phone 01858 433 775
e-mail sales@pramsnthings.co.uk
Oct 06, 2009 | Maclaren Quest Stroller Standard
Want to upgrade babytrend stroller wheels
Unfortunately they make them the way no other wheels will fit on there, you can look for a jogger that has big air filled tires they will be easy to steer.
Aug 31, 2009 | Baby Gear
Replacement wheel
The rear number is 2036627, there is no side casing, you would have to replace the whole back, which Bissell isn't making avaiable. But o get the wheel, you might try bissell.com and see if you can order direct, or try a local repair shop to see if they will order it for you.
May 06, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Quinny ZAPP Stroller Logo
100 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
