Question about Brother DCP-350C InkJet Printer
My printer said that there was no ink when there was
My DCP-350C printer said that there was no ink left in the yellow ink cartridge so i took it out and looked at it but there is still ink in it so i put it back in. Now the printer says that there is no yellow cartridge even in the printer and keeps telling me how to change it and wont do anything else. how do i get it to recognise that there is a cartridge there and that it does have ink in it? otherwise i can't use the printer at all
  • 92 Answers
IN THE PRINTER SETTINGS THERE SHOULD BE AN AREA FOR TEST PRINTING AND CLEANING THE HEADS. RUN A FEW CLEANING SERVICES. FAILING THAT UNINSTALL THE ORINTER DRIVERS AND DOWNLOAD THE LATEST ONES FROM THE MANUFACTURES WEBSITE AND REINSTALL....HOPE THIS HELPS...
Posted on Nov 17, 2009
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
Where to load the ink cartridges in dcp 350c
on the front right hand side pull the panel forward.
Oct 06, 2010 | Brother DCP-350C InkJet Printer
Install ink and not been used however tried putting inks in more than once yet it still say no yellow pink or magenta
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts.
Sep 26, 2010 | Brother DCP-350C InkJet Printer
Print is fuzzy/shadowed. Ink cartridge has been replace but no improvement
Please print Nozzel cheak 5/6 times,But remember your cartidge ink will be lost all at a time.
Aug 16, 2010 | Brother DCP-350C InkJet Printer
Brother DCP 350c
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jul 27, 2010 | Brother DCP-350C InkJet Printer
Empty yellow cartridge, but cannot print in black?
Most printers use a little of all inks in their functioning, just to keep all the inks flowing, so while it is not printing yellow, it uses it in the startup mode to verify function and cleaning mode to clean the nozzles. Manufacturers usually do not put in a bypass for this, because they make money mostly on selling you ink cartridges.
Jan 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Dcp-350 c all-in-one printer ink jet
Here is the link to the Brother DCP-350c download section for the Software that you will need.......http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=dcp350c_all
Copy and paste into your browser if the link is not in blue or underscored.
Nov 10, 2009 | Office Equipment & Supplies
I have a Brother DCP350 and no yellow ink. But tonight I have to print a document. Will the printer work without Yellow? I have been trying for an hour now and cannot print anything.
Hi matt651, I had the same problem with the DCP-350. As soon as one of the colour cartidges was empty, which happened frequently due to the high ink loss during the cleaning process, the machine stopped working, even when I only wanted to print using black. This is how i worked around the problem using a piece of grey card stock: The tanks have a small clear window that lets you see the ink in the cartridge. This window also triggers a photocell which sits in a little black fork at the back of each of the printer's ink cartridge slots. When the ink levels are up, the cell is blocked, thereby indicating a full cartridge. When the ink level in the cartridge drops below the photocell, the cell switches over, indicating an empty cartridge. So in order to simulate a full ink catridge I removed the offending empty one and instead slipped a piece of cardboard into its slot, thereby fooling the photocell. And hey presto, when I switched the printer back on, all ink cartridges thus manipulated were shown as being "full" and I could continue printing.
Kind regards, Rog
Nov 27, 2008 | Brother DCP-350C InkJet Printer
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-350C InkJet Printer Logo
150 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
