Question about Alpine CVA-1003 Car Video Player
Help hey i have iva-c800 and when i place a dvd doesnt show the picture it shows the safety mode what ground wire need to hook up or how conect the switch i dunno how would pls help me
  • diwey Jan 11, 2008
    well i have conected the yello/blue to the ground it shows me the same safety mode but they say alpine's need a a switch to conect but i dunno what cables to hook up to the switch
  • JOECHEVY2009 Jan 07, 2009
    i have a ALPINE IVA-C800 and i wired everthing but i still get the picture in safe mode how do i fix this problem yellow/blue wire is connected to my brake ground
    Brigadier General:
  • 6,966 Answers
Depending on the vehicles wiring itself, Alpine uses the below color coding for its wiring:
yellow – constant +12v such as the positive battery terminal
red – switched 12v such as the accessory terminal of the IGN switch
black – ground which could be the chassis/body ground of the vehicle or the negative terminal of the battery
blue/white - remote trigger for add-ons such as a power amplifier
blue – will activate a power antenna (if present)
white and white/black - front left speaker + & -
grey and grey/black - front right speaker + & -
green and green/black - rear left speaker + & -
purple and purple/black - rear right speaker + & -
orange/white - reverse wire
white/pink - monitor control lead
pink/black - audio interrupt from mobile/cell phones
yellow/blue - parking brake
yellow/black - foot brake
To bypass, the yellow/blue must be triggered negative/grounded. Alternately, it may be easier to use an adapter such as a Peripheral PTR7 (http://peripheralelectronics.com/). In some regions, it is not allowed to operate this unit while vehicle is in motion.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck, kind regards and drive safe.
Posted on Jan 10, 2008
  • Louie  Role
    Louie Role Jan 11, 2008
    Hi again,
    Have you tried wiring the yellow/blue as instructed by Alpine to the parking brake?
    If yes, and the unit operates when "parked", then what is needed is a SPDT switch that will supply +12 to the said wire when not in operation but switchable to GND when you wish to operate. What it does is simulate the condition of activating the parking brake.
    If yes, and the unit still fails to operate, then the unit may require the services of a qualified repair technician and not just an installer.
    If no, perhaps you need to try it to verify whether it is the wiring or the unit that causes the "Safe Mode".
    As initially posted, have you considered the Peripheral PTR7? Its product description is "Universal Trigger/ Video Bypass Module".
    Cheers.
IVA-D106 Car DVD Player: no picture on screen while dvd is playing...
Im guessing that if you can hear sound but have no picture and this is newly installed that your unit is wired to your parking brake as a safety feature. You need to disconnect it and connect the wire to the radio ground to bypass it.
May 18, 2010 | Alpine IVA-D106 Car DVD Player
TV was moved and all wires disconnected..can't find installation
hey man just look at the wire lead and even also to the conector and then conect them with each other and try to play it
May 15, 2010 | Bose (321GS) System
What color wire do i hook the pink wire to
Pink wire is generally the parking brake safety. If you dont want the dvd player to play video while in drive wire it to the ground on your parking brake sensor wire. If you do want it to play video while your driving, wire it directly back to the ground wire on your stereo.
May 15, 2010 | Alpine IVA-D300 Car DVD Player
Kenwood kvt-719dvd plays dvd but wont show picture
It is probably that the parking safety wire wasn't hooked up properly, or at all. Most in dash dvd players are equipped with a motion safety device to prohibit the driver from viewing movies and such on the monitor while the vehicle is in motion. The wire for this needs to be hooked to the parking brake light wiring. This will ensure that when the parking brake is on, the dvd can sense that the vehicle is stopped, and should therefore show the image.
Mar 15, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
Where does the parking brake wire hook up in order to bi-pass this option on alpine iva-c800 car audio system
based on my previous experience with the Alpine Mobile Multimedia Station, 1 wire needs to see 12 volts ie. brake light wire, the other needs to see ground ie. parking brake.
You can hook up the wire that needs 12 volts to either ignition or some other 12 volt source. The other wire needs to be connected to a toggle switch to ground. Then flip the switch as needed to simulate the parking brake and voila...
Aug 13, 2009 | Alpine IVA C801 Car Video Player
How do i bypass the parking brake switch on my eonon
all u gotta do it the light pink wire that has brake label on it, connect it to the casing of the dvd itself, thats what I did, works like a charm, u might gonna have to run it through an opening of the casing and twist it around itself to hold in place
Sep 24, 2008 | Alpine IVA-D310 Car DVD Player
Need brain unit and wiring harness
i need a brain unit 4 an alpine IVA-C800 please help!
Aug 21, 2008 | Alpine IVA C801 Car Video Player
Alpine IVA-D310 No Menu
you need to make sure that you have the TR-7 or that the parking brake and foot brake wires are hooked up. with out them there will be no picture or menu.
Jun 07, 2008 | Alpine IVA-D310 Car DVD Player
IVA C800 ALPINE
I BOUGHT ONE OFF EBAY AND TRIED TESTING IT OFF A 12V CONVERTER. COULD NOT GET IT TO TURN ON! INEED HELP TO
Jan 15, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Alpine CVA-1003 Car Video Player Logo
292 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
