Question about JVC Video Cameras
Can't see through lens in camera mode it says lens cap on but it's not
  • 405 Answers
Common problem with JVC camcorders, CCD ( imaging IC) went bad, CCD requires replacement.
Posted on Nov 17, 2009
  • edwardmd Dec 15, 2010
    My JVc gz-mg57e/ek has same problem thinks lens cap is on. If the CCD needs replacing is it worth replacing? Where would you take it?
What does remove obstruction mean
Is mirror in locked up position? In manual mode? Especially if the lens is irised down to a high f-stop.
Aug 24, 2014 | Fuji FinePix Cameras
The screen stays black. Yes, I have batteries, I do get instructions and images for video or camera, but I can no longer get a visual of anything the camera is aiming at. It's like there is a lens cap on...
Look at the front at the lens. Turn the camera to picture mode. Point the camera at a light above you. Take a few pictures and watch the lens.
You should be able to tell if is functioning correctly or if its broken. It sounds like it has been dropped.
Your Friend,
Sleek Mouse
Mar 15, 2011 | Cameras
Keeps saying to turn off camera and won't take pictures
What the troubleshooting guide suggest is to turn off the camera and turn it back on which sound like what you have been doing. The cause of this generally points to a camera malfunction between the camera and lens. This makes me believe that either something is restricting the lens from moving like the lens cap is tethered to the camera and tight on the lens so it can't do it's "pre" view and goes into the shut down mode. If the lens has any restriction be it the lens cap, ever ready case or anything that is restricting the lens movement remove it and try it again. I have another theory which is completely opposite to anything even suggested and that is the camera can't read the SD card so goes into shut down mode. If you remove the SD card and check to make sure the "lock" switch is in the unlock position. I'll give you a diagram for this.
The little switch needs to be pushed forward towards the gold contacts.
Diagram
Jan 09, 2011 | FUJIFILM FinePix S1800 Digital Camera
In camcorder mode the prompt "LENS CAP" is displayed, no picture
i get the software to download right on the toshiba deanna gilliland
Dec 14, 2008 | JVC Everio GZ-MG30US Camcorder
JVC GR-250U
There should be a cose number when it is showing safe gaured mode.what is that.For the lens cap may be there is loose contact with ccd cable or you have to change CCD base assumbly.
Jan 29, 2008 | JVC GR-D73E Mini DV Digital Camcorder
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Jan 15, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Can't see out of viewfinder
The mirror motor is probably the problem, you'll usually hear a whirring noise like a motor spinning. It's about a $125 repair, requiring the mirror box to be removed and the mirror driving motor replaced. Pentax originally put a plastic gear on the motor shaft - the replacements have a brass gear.
Nov 25, 2006 | Pentax ZX-30 QD 35mm SLR Camera
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Video Cameras Logo
360 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
