Question about Tappan TGF320 Gas Kitchen Range
How to convert from Nat. gas to propane to gas Tappan
    President:
  • 1,653 Answers
You can buy a conversion kit from Tappan. Its pretty much a case of changingthe injecors for each burner and the ovena nd grill then changing the main gas inlet hose and then testing.
Posted on Nov 17, 2009
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
How do you change a change glo-warm sit 630 from natural gas to propane
You cannot do it. Their is no way. These come in 2 versions. Natural OR propane and they cannot be converted. The pilot is designated as a nat pilot assembly and the gas valve is designated a nat only valve. Their is no way to convert it not without costing a ton of money. You would need a LP gas valve and an LP pilot assembly. It would be better just to sell it to a nat gas user and get an LP one.
Jan 09, 2013 | Kitchen Ranges
Convert propane to natural gas on tappan TGF657 range
go to hardware buy a valve for that type fuel and change them out
Feb 04, 2012 | Tappan TGF657 Gas Kitchen Range
How do light an old Tappan gas range?
If it has a pilot light: themobilian_411.jpga little gas comes out all the time on these. Just use a lighter. Warning for propane model have plenty of ventilation before attempting to light it. Propane is twice as heavy as air and nat gas is lighter than air. propane puddles and lingers while nat gas dissipates. If yours has a glow bar no need to light it:
Dec 11, 2010 | Tappan Ovens
Maytag Range Model MGR5870 how to convert to propane
set the regulator to propane and change the orfices to the blk ones. copper is for nat gas / black for propane .. thanks hope this helped .mm
Dec 22, 2009 | Maytag MGS5870 Gas Kitchen Range
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Natural gas to LP converters
Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Feb 05, 2009 | Tappan TGF320 Gas Kitchen Range
How to convert a drier from nat to propane gas i dont have the instruccions
NOT SURE BUT DON'T THINK YOU CAN USUALLY CAN GO FROM PROPANE TO NAT BUT I KNOW WITH FURNACES YOU CANNOT GO FROM NAT TO PROPANE AND THAT IS THE CASE WITH GAS LOGS AS WELL BUT NOT 100 % ABOUT DRYERS .
Dec 23, 2008 | Kenmore 73952 Gas Dryer
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
CONVERT NATURAL TO PROPANE
you will need to change the injector (orrifce ) to a propane one the burner should burn nat gas and propane
Jun 27, 2008 | Rinnai RER-55AS 55-Cup Rice Cooker
Tappan TGF320 Gas Kitchen Range Logo
170 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
