how do i restart the pc in safe mode?.. it happens like this: i unistall the driver for the touchpad and restart the laptop, after the laptop has restarted the touchpad works and a message pops up saying restart for the new updated touchpad so i restart it and it does not restart thankshow do i restart the pc in safe mode?..
thanks
You can't post conmments that contain an email address.
ok then plug a usb mouse then restart the computer
got to the computer manufactures website and look for support to download the touchpad driver , install it, disconnect the usb mouse and restart the laptop i if it sttill doesnt work its probaly the touchpad that needs replaced.
Try a restart if that doesn't work, connect a usb mouse and go to the device manager and see if the drivers for the touchpad are installed. If they aren't, go to http://www.hp.com and input your model number into the search box, there will be a place to download the touchpad drivers. Install those and your touchpad should be working.
i would go to device manager
scroll down and find the touchpad
uninstall it
then restart and hopefully windows
will find new hardware on restart
and install the touchpad correctly for you
Your Touchpad is disabled, thats why its not working, to enable again, simply press Fn+F7 Key, you will see a small blue icon on F7 key, with a finger pointing, its basically a short cut for enabling/disabling Touchpad,
If it doesnt works, restart your laptop once, and restore the BIOS settings to default, save the settings and reboot laptop, and it should be working again,
Feel free to reply to this post if you require more assistance,
Regards-BA
hi,
welcome to fixya
i got it if ur touchpadis not working the first f all all u need to do is that update the touchpad driver from the control panel,if it i xp,go to start>control panel>kyboard>update the respective driver or downlaod the latest driver from the Acer Aspire website and then restart th computer and check it out.if it stll doesnt work the definatey replace the touchpad.pls rate this soluton...thanks
the first thing what u can try is that try and uninstall and rsintall the touchpaddrivers and then restart the comuter and then u cna try and try and work on the touchpad and the stil it doesnt work then what u can do is if it is less then a week then u can do the system restore back to an earlier date beore a week when the touchpad was working fine and then what also u can try is that u can try and chekcit out in the safe mode.....good luck....
u can try this all u can do is just go to this website and click on driver detective scan now and then click on the download now and then restart ur computer and then the touchpad should work and still if it doesnt work then uninstall and resintall the touchpad driver and the synaptic drivers and restart the computer and still if it doesnt work replace the touchpad from dell...the website is http://www.drivershq.com/Drivers/VistaDevices/Dell-Input-Dell-Touchpad-Pointing-Stick-Driver/13926/Drivers.aspx ................... thanks
go to device manager and reinstall the touchpad synaptics driver...restart your system...it sholud work..otherwise you need to contact lenovo support for touchpad replacement
thanks
