Question about 3M MP 7720 Multimedia Projector
I have a 3M MP7720 projector, unfortunately the PSU board has failed and blown T101. Can anyone tell me what IC T101 is as it is completely destroyed so I can't read any identifying information. Thanks
  • 2,237 Answers
Chances if that got destroyed, it took out peripheral componets as well. might as well replace the board.
Posted on Jan 27, 2010
Need a power supply for a pmh5000 and install directions
These are delivered with a power supply. If yours has failed, LIKELY there are other problems. I have repaired several supplies and can coach you through which parts to replace. Often the failure originates with a shorted MOSFET in one of the amplifier channels, usually the rearmost one. Getting parts for these is really hard as FullCompass is the Behringer parts distributor. The SPS1000 supply takes out about $25 of parts when they go. The hardest parts to replace are the IGBT transistors as the heat sinks are hard to remove to get the screws out of the transistors. All the repair parts are available using five different online sources.
Sep 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Simply fails to switch on. Mains fuse OK "Special" fuse of PSU board OK.
Check the lamp door. There is an interlock there that will prevent power-up if the door is open at all It should be a small post on the door that enters the projector to compress a micro switch. If the post is broken or the door is not completely shut, the switch won't activate and there will be no power.
If that is not the case, please update this and we'll lok further.
Thanks,
Dan
Feb 26, 2010 | Acer PD523 Multimedia Projector
I have recently bought a second hand 3M projector, and when turned on the screen shows half Blue (i think) and half Red and when used via the laptop the red shows through on the right hand side, can anyone...
first reset the settings to factory default. you may have to realign the lcd panels and make sure the panel ribbon cables are properly seated. otherwise, you have a main board issue.
Jun 22, 2009 | 3M MP 8765 Multimedia Projector
3m projector color issue!
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll need to replace the whole optical engine.
Dec 15, 2008 | Office Equipment & Supplies
Loud Bang and Projector no londger works
If the internal fuse has blown, if you connect the power lead loosely and move it about, you should not be able to hear any crackling sound of electricity. If you do then it is more likely something else other that the internal fuse. Generally, a loud bang is either the fuse or lamp.
Sep 25, 2008 | 3M MP 8749 Multimedia Projector
Power swith ic went bang!
unfortunately these boards are now obsolete, it may have damaged the bridge rectifier
Nov 06, 2007 | Samsung PS42P2S 42 in. Plasma Television
No power to projector
Generally when the globe goes end of life and needs replacing the unit will fail to power up. Try another globe if you have one spare.
Sep 10, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Jul 03, 2007 | Sharp 27K-S100 TV
3M MP 7720 Multimedia Projector Logo
75 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
