Question about Microsoft Xbox 360 Console
E73 error and one red ring in the lower right quadrent. AV power cord when unhooked- no red light- when reattached red light reappears.
    Genius:
  • 1,093 Answers
1 red light is the display chip overheating and to fix it you need to stop the heat build up getting to the main chip to do this you need to send it in or use a good xbox 360 repair guide to fix it
Posted on Nov 17, 2009
Have a partial red ring. in the 4th controller position, with a E 73 code on the screen. how do i fix it?
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
E73
http://www.xbox-360-red-lights.com/solving-xbox-e73-error
Got the Xbox 360 E73 error? Want to get it fixed? Fact is that this problem may be tough to fix, and that's why many people will tell you to send your console over to Microsoft and pay $150. But is it really worth your $150? Is there maybe another way to get it fixed? The Xbox 360 E73 error may be tough to fix, but this doesn't mean that you can't repair it by yourself.
Fix Xbox 360 E73 error by Microsoft or by myself?
So what to choose? Well, if you send your console over to Microsoft, you will have to pay $150 if your warranty has been expired. Also, you will have to wait for 2-6 weeks before you can get back to playing. You'd better want to avoid this... Right?
It can be done way faster and cheaper... If you fix the Xbox 360 E73 problem by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, visit: Xbox 360 Repairs
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix E73 Error
Apr 13, 2010 | Microsoft Xbox 360 Console
One red light flashing bottom right , what is wrong .
A single flashing light can mean a hardware failure. Did you get an error code? EXX where XX is a number...like 74 for instance? Please, let me know, and try this.
Power off the system and unplug everything from it..controllers, memory cards, av connection, power cord, and hard drive. Also unplug power cord from socket and the short cord from the power brick. Then reattach everything making sure the connections are firm and power back on your system. If this did not resolve the problem.
Apr 02, 2010 | Microsoft Xbox Console
E73 Error
Error E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
This error is also caused by a cold solder joint under the Southbridge or the Ethernet chip.Can also be one of the solder joints that lead to the GPU.
check if you are getting any flashing red lights on your xbox 360 power up button, if you are not getting any flashing lights the probably you may try unplugging any Ethernet cable attached if you had tried connecting to Xbox Live and at that time you face this error, re-connect and check
If you still get this problem and you see a single flashing red light on your console, please send your console for repair to MS support if it is under warranty
Dec 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 has shown up one red flashing light and E73
HI. This is an Ethernet port issue.
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try using a new Ethernet cord. If the error continues after the new cord is used, contact Microsoft for a repair ticket. the port will need to be replaced. (Internal connection failure)
Possible solder break
Oct 13, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 error code e73
The Internet Port or Referred as the CPU or GPU is fried and needs to be turned in the Microsoft for repair. No other way that i Know will fix it.
Jan 12, 2009 | Microsoft Xbox 360 Console
Lower right quadrent blinking red
MS suggests power up the unit without the hard drive. Also, you'll want to disconnect all ports (USB, Controllers, etc). After you have powered up, turn it back off, and connect everything again.
- Davis
Digital Analog Therapy
www.REPAIRNYC.com
Aug 06, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
I have an xbox 360 which is defaulted wen i turn on instead og green light there is a red light too.
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Jun 30, 2008 | Video Game Consoles & Games
My xbox 360 has one flashing red light, and it keeps showing me the code E 74
Jun 29, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
114 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
