Question about LG Vu CU920 Cellular Phone
Where is the SD card port on the CU902 wine model?
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
How do i use the mmc/sd port
Hi !
First, you have to make sure that you have installed the proper drivers for your mmc/sd port.
http://support.hp.com/us-en/product/HP-Media-Center-m7000-Desktop-PC-series/1847154/model/3185130/drivers
Restart after installing. After that, just insert the mmc into the slot and you should see it on "My Computer" or press Win+E.
May 22, 2014 | HP Pavilion m7570n (EX331AA) PC Desktop
Where to insert sd card
Normally the sd card slot will be on the side or in front of the laptop if it has that option. Not all laptops have sd card slots.
If your laptop does not have the sd card slot, then you can purchase a sd card reader that plugs into your usb port on the laptop for less than $20.
Try Tiger Direct at: http://tigerdirect.com
Below is a multiformat sd card reader for $9.99 at Tiger Direct.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=186067&CatId=2825
Also your camera might have come with a cable that plugs into the camera and the other end into the laptop's usb port. Once you have the cable connected, turn the camera on and the computer will recognize it. You can then search through the camera folder for the pictures or videos. If you use this method, you leave the SD card inside the camera.
May 20, 2012 | Computers & Internet
Toshiba flash cards not working
Flash Drive or SD Cards? Flash Drive is where you put the mechanism into a USB Port. SD Cards are where you might take the card out of a camera and stick it into the SD Card Reader Slot on the computer.
Which one are you saying is not working? If its the SD Card Reader, go download and reinstall the driver again.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Card Reader drivers.If all fails maybe your card reader has gone bad. You can always purchase one for under $10 that plugs into the USB Port. When the site below comes up just type: SD Card Reader in the white search box and hit GO. The link is below:
Apr 21, 2012 | Toshiba Computers & Internet
How to view pictures off of my micro Sd card on my AX380 model phone
Connect the supplied USB cable from your cell phone to theUSB port on your computer.
The computer will see the cell phone as an external storage device or anexternal mass storage device, you can then open the photo folder on your cellphone and copy the photo to your computer. If the photos are stored on a mini or micro SD memory cardthen - An alternate method is to remove the mini or micro SD memorycard from the cell phone and insert it into an USB card reader then connect itto the USB port on your computer. Youcan then open the photo folder on the micro or micro SD memory card and copythe photo to your computer.
Sep 09, 2011 | LG Wave AX380 Cellular Phone
How do I use the Micro SD port?
hi.
sd port is use for read yr sd card.. put yr sd card in sd port then yr can read it from clisk my computer icon and ten yr card will be locaten in g/h/f or try click 1 by 1 memory stick drive
regards
Feb 21, 2011 | eMachines Desktop / AMD Athlon Processor /...
How do I download photos from LG VU (CU920) cell phone to my computer?
you can use the bluetooth feature if your computer also has bluetooth capability. if not, hopefully you're using a mini SD card. if your computer has a port for mini SD's, then just take the mini SD out of your phone and plug into your computer. if your computer has a regular SD port, then you need to get yourself a mini SD adapter. it looks just like an SD card, but it has a small opening to slide your mini into. if there are no SD ports on your computer, simply buy yourself a Flashdrive (thumbdrive) that has a port on it for mini SD cards. then, just plug that into your USB port.
if you're not using a mini SD card in your phone, then you need a data transfer cable, which you probably have to get from AT&T. i tried radio shack, but they didn't have them. In my experience, using a mini SD card provides the most compatibility. hope this helps.
Feb 06, 2010 | LG Vu CU920 Cellular Phone
I just bought a vltech digital photo frame and i'm not sure how to download the pic's on to the fram from my computer or my iphone. do i need some type of memory card to upload pic's? model DPH3080E
Does you picture frame have a usb port on the back or the side of it? If not, do you have an SD slot on the back or the side of it? If so, load your pictures onto a thumb drive (flash drive) or SD card, and insert that into the port if it's a flash drive, or slot (if it's an SD card). It should take over from there. Let me know if that helps.
Rob
Dec 29, 2008 | Vtech Kidizoom Digital Camera
LG Vu CU920 Cellular Phone Logo
52 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
