Question about Canon PIXMA iP1800 InkJet Photo Printer
Paper feed Hey, i got a problem with my printer. It turns on and everything, got inks in them. It was working fine then suddenly it just wouldn't print anymore. Every time i had tried to print, the paper doesn't go through except it kinda shifts it on the right side and the printer thinks theres paper in it except there isn't and inks just splats inside.. so whats the problem...
  • 5 more comments
  • Anonymous Jan 28, 2008
    I have this same problem. Does anyone know how to solve this?
  • Anonymous Feb 12, 2008
    The same thing is happening to me. Just out of the blue it started doing this. Anyone got a solution? So many people with this problem and no support? This is ridiculous.
  • couturiere Mar 11, 2008
    same exact problem! it's driving me crazy. i can't find a solution!
  • Anonymous Apr 10, 2008
    I have the same problem. Paper feeds down about 1/2 inch and then popup error message about paper jam and there isnt a jam.
  • schlumgolian Apr 10, 2008
    i hhjkkll.
  • penshoppe_so Nov 16, 2008
    what should i do for this problem or what is the solution?
  • Anonymous Apr 09, 2009
    Pulls to the right causing a jam
I have a mid-term that is due tomorrow. What a piece of ****!
Posted on Apr 21, 2008
What the hell, I have a mid-term that is due and I need this thing to work, What a piece of ****!
6ya staff
SOURCE:
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Ink and paper lights flashing alternately epson c64 photo edition. paper fine, ink levels fine, power fine, comms with computer fine, still wont work, Help.
-turn off printer
-disconnect from computer
-load a couple sheet of plain paper
-press & hold paper feed button while turning the printer on
-it should print a test page if it is working fine, otherwise it is bound for service
Apr 02, 2010 | Epson C64 InkJet Printer
My printer thinks it is out of paper when it
please try to set it to manual feed
with manual paper feed it wont search for a paper and wont give an error
Thanx and i hope this helps
PLease rate this solution
Jul 16, 2009 | Epson Stylus Color 777i InkJet Printer
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Paper feed problem
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer paper feed error #3
Dear EATRUNNER,
This Error is related to PaperJAM now you can find the complete solution to related this Error ,on this URL:
http://support-au.canon.com.au/contents/AU/EN/8000647001.html
i'm 100% sure ,your problem is solved ,whenever you read this page properly.
Cheerup and Be Happy Always
Mar 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam, when there's not a paper jam?
there is a small micro switch , when paper is loaded that switch
is activated, bent switch, paper shreds jamed in switch, will cause paper feed problem.
Jan 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper won't feed
The paper is pulled in with rubber traction wheels on a rotating rod where the bottom of the paper sits in the loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use.
Aug 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Paper handling problem
I don't know if it happen anytime while it prints, but once I turn it off then turn it on again those fingers sit down just like before and everything is fine, hope that will work 4 u
Jun 15, 2006 | HP DeskJet 3550 InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
97 people viewed this question
Clive
Clive
old marine
old marine
Ekse
