Insert toner card error for ricoh 1140l
Insert the toner card error for ricoh 1140L
I AM LOOKING FOR A DRIVER FOR THE 1140L FAX MACHINE FOR OS 8 LAPTOP
finding drivers for fax machines is becoming increasingly more difficult.
you might need to use something like bios agent or driver agent to find something compatible that will work.
Nov 15, 2016 | Office Equipment & Supplies
Drivers for my printer ricoh fax 1140L
hello i have a question, is ricoh 1140L a printer also?
Mar 01, 2011 | Ricoh Office Equipment & Supplies
Hello, I have a fax machine which is for business use and used daily throughtout the day, we have a problem, the fax machine is a RICOH Fax 1140L. There is an error on the screen sayinh 'Printer Error...
There is not much that can be done from the outside as your fax is showing an error due to a failure in the system circuit. Best that can be tried is to remove paper, clean the head with a soft cloth clean the paper insert section. Put the fax on and if the fault message comes on again, you will need to open out the set to probe into the main board. remove back panel and reinsert all connectors , If there is no result, you will require help so that we do not tamper much. Good day
Aug 14, 2010 | Computers & Internet
How can ib reset e`rror code of ricoh fax 1140l (printer error fuser temp)
Sir,
this error usually ocurs when you towner is empty or have completed is age.But as you said error fuser temp this might be that you priner buffer has got damaged while it repaire able bus is expncive so I would rather suggested to buy new one printer and Canon and HP are the best brand in my dictionary so you can try one of them.
Nov 08, 2009 | Samsung SF 5100P Laser Printer
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Insert toner card
I think you mean insert the toner cart, meaning just that, if you just put a new one in is it OEM, and if it is try gently shaking it to unclump the toner in it. -Carl
Jul 07, 2009 | Ricoh FAX2900L Plain Paper Laser
Ricoh 1140L doesn't print all pages
Does this happen from all senders or a specific sender?
If it's a single location then it is a conflict -some combinations of machines simply don't get along well together
If it happens from all locations, you may try a line filter. Interference on the telephone line will cause problems.
May 20, 2009 | Office Equipment & Supplies
Ricoh Fax 1140L
The only reset there is for it is to turn it off, wait 30 seconds, and turn it back on again. If it appears again, it needs service in case the thermistor needs to be replaced or something else.
Aug 07, 2008 | Samsung SF 5100P Laser Printer
356 people viewed this question
k24674
jasbo
jasbo
