Question about Refrigerators
Freezer is icing up inside snow/ice is building up inside the freezer especially in the top shelf. The fridge is also not so cold. The component that connects the fridge to the freezer is mostly blocked with ice. I melted the ice with a blow dryer last week- but the problem happened again.
    President:
  • 2,702 Answers
It may be the door seal not closing right up,and its letting in warm damp air,,,or it could be that the door is opend a lot of times in a day,,,all let in damp air witch freezes
Posted on Nov 17, 2009
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator with top freezer either model GR2 or 9FHTXT will not keep get cold
Sounds like the defrost drain has become iced over or clogged. This is why the ice builds up.
Jan 14, 2008 | Refrigerators
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
