Question about LG VX8300 Cellular Phone
I dropt my LG VX8300 in water....
I had this thing for months but dropt it in a glass of water, I dried it out, the battry is fine, it just bugs out all the time Help!!!
Put your phone in a enclosed box, filled with about a inch of cat litter. The cat litter will draw out the moisture. Leave phone in box, with back cover off. For at least 2 days.
Posted on Apr 11, 2008
    President:
  • 1,017 Answers
Not a lot you can do for this problem, you could try taking all the removal bits off the phone, and drying them with a hair dryer on
low heat.
The chances are something will be fused in the phone.
AC/DC power and water don't go together.
Posted on Jan 16, 2008
6ya staff
SOURCE:
My phone keeps saying use genuine battery when i plug it in
You have water damage...
REMOVE THE BATTERY!
*Choice one- Methyl Alcohol
Clean the circuit with Methyl Alcohol
  • Dip a q-tip in the alcohol and squeeze the q-tip.(you want it to be almost dry)
  • Very carefully clean the circuit and allow it to dry, it is important that you clean around the medal to prevent short circuits.
*Choice two- Rubbing Alcohol
Clean the circuit with Rubbing Alcohol
  • Rubbing alcohol has a slower evaporation rate so you need to wipe the area with a clean q-tip after cleaning it with the alcohol.
If this dose not work you need a new phone, good luck.
Aug 15, 2009 | LG VX8300 Cellular Phone
Dipped phone in water
http://video.about.com/cellphones/Revive-Waterlogged-Cell-Phone.htm
cover your phone in white rice overnight--withoutthe battery or the back on it----it would work ---hope it works for u shannon
Aug 09, 2009 | LG VX8300 Cellular Phone
Water damage on LG 8800 venus
FILE IT AS STOLE AND YOU CAN GET A NEW ONE B/C THERE IS NO COVERAGE FOR WATER DAMAGE
Dec 14, 2008 | LG VX8300 Cellular Phone
Lg scoop not charging
the battery is heavily damaged or the connection of the charger is damaged, the only option is to have it looked at professionally or to purchase a new phone, i've had the same problem
Sep 25, 2008 | LG VX8300 Cellular Phone
LG VX8300 camera "fails to start"
The camera seems to have failed. Take it to the verizon store and they will get you a new phone :)
Jul 31, 2008 | LG VX8300 Cellular Phone
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
Vx8300
Please increase your phone vloume and cheak the spaker is working fine are not
May 25, 2008 | LG VX8300 Cellular Phone
LG VX8300 front and main screen are black.
2 possible causes - the LCD and/or LCD electronics PCB board is faulty OR the flexible ribbon cable may be kinked or broken. If you are knowledgeable in electronics repair, you can make this fix yourself.
Jan 15, 2008 | LG VX8300 Cellular Phone
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
VX8300 Phone! Problem!!
JJulie, I had a similiar problem with my phone (lg vx8300) where it would show a white screen saying "use genuine battery" and then power off automatically. Although there was no contact with liquid, there were signs of water damage (high humidity in my area, camera lens had some moisture) on the battery and phone. If you open the battery door, look at the bottom edge of the battery (where positive and negative posts are), and the spot on the phone located where the battery would line up with this dot. If either/both dots are red, then there has been liquid damage, and you will need to replace the phone. I understand that this is not good news, for me it meant that I had to pay to replace the entire unit. Check to see if you have insurance with your phone plan to get a lower cost replacement. Sorry for your loss, and hope this helped.
Jul 29, 2007 | LG VX8300 Cellular Phone
LG VX8300 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
