Question about Maytag Refrigerators
Maytag plus msd2556aew freezer working good but evaperator collecting ice.fan works good ...frige side not getting cold...hear a buzz noise on the frige side near the lights
  • 612 Answers
This is caused by a defrost problem, most likely a bad heater($44.66+sh part# 12 under freezer compartment diagram PS2061407 ). If the heater is good ( has continuity) the defrost assy ($66.22+sh part# 13 under controls diagram PS2061226 )will be bad. Go to www.partselect.com and enter your model number. It will bring up diagrams of your unit. This will show you where the parts are located and what they look like. Either one is easy to replace. Once you click on the part you need, it will take you to a sight that gives you the price and also below that it will have where people have changed the part and how to do so. Good luck and have a great day.
Posted on Nov 17, 2009
Frige working fine but freezer not working. Temp at 43 degrees and doesnt respond to changes from the front panel. It made funny "bubbling" noise. Ice is also not putting out.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Maytag MFI2266AES Stainless Steel Bottom...
Maytag MSD2556AEW; Fridge and freezer not cold
Without actually putting gauges on the system to see what is really going on, I would say that your compressor has failed. There is a good chance that it is something inside that has broken. Turning it off and back on will give it another life sometimes but like youexperienced it is usually short lived.
I assume that you have checked that the condenser fan is running underneath the fridge. Also that the condenser coils are not completely plugged with dirt. These things can also make your firdge od wierd things...
This should give you a couple of things to checkout, but I fear that the compressor is bad and you will need to replace it or get a new refrigerator. If you choose to replace the compressor get a full price quote before the work is done, as it may not be worth doing if you have an older refrigerator.
I hope that this helps you to solve your problem.
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a maytag side by side and the refidgerator is not keeping things cold. The freezer works fine . It mkake no difference where we put the thermostat at
check for ice build up on back wall of freezer if you have ice on wall you have a defrost failure it is very common the vent clogs and cool air cant get to fridge sectiondepending on modelyou have either an electronic defrost control or you have a defrost timer and limiter both systems have common heaters either controlled by an adc board or timer and limiter if you have no ice build up thacommon repairn its most likely a bad evaperator fan relatively
Aug 18, 2009 | Maytag Refrigerators
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Frigidare
only 5 years is important, sounds very much like you have a bad compressor, It's trying to start asn cant so it shuts down(therees the noise your hearing. 5 year manufacture warr. so see if you can find your bill of sale. and give manufacture a call
Mar 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Maytag side by side refrigerator
fridge has timer to adjust for defrosting, but the not working working you to manual defrost the unit to avoid ice formation inside the fridge.
Dec 30, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
292 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
