Question about Mitsubishi WS-65807 65" Rear Projection Television
I have a Mitsubishi Rear Projection TV model WS65807. Need main signal board part #930B868001. Fits on chassis V-17. Repairman fixed orignal problems and 4 weeks later lost picture. He called Mitsubishi and they said the above was the problem. They do not make part any more but could probably find on the web. 3
  • 1 more comment
  • raykuehn Nov 19, 2009
    Invested approx $900 into repairs several weeks ago and we had an awesome picture, better than new. We lost picture, repair man came back and called Mitsubushi..we will need this part to fix the TV. Should I invest more money? The TV is old but we really don't use it much. The repairman feels bad...said if I could find the part he would put it in, no charge. He's an authorized Mitsubishi Dealer/Repair company.
    Thank you so much for your help
    Great Help and advice
  • Mitsubishi Master
  • 19,396 Answers
Hi.
This is a well known problem on this model. The fault is often caused by a coolant leak dripping on top of the signal board and damaging the signal board.
The only seller that is keeping 930B868001 in stock is asking $350 for each board.
MITSUBISHI 930B868001 PCB-SIGNAL IN STOCK
Because of the signal board problem you can often find this model on craig list, or on Ebay: Mitsubishi ws-65807 65" widescreen
I also suggest calling Mitsubishi and asking them if they can arrange repair.
Regards.
Posted on Nov 19, 2009
  • Ginko
    Ginko Nov 19, 2009
    Hi.
    If you have already invested all this money, then it may be worth purchasing the part, and having it installed at no extra cost.
    Ask also the technician before purchasing, he has tested your TV.
    If you want you can also try contacting the seller here.
    Regards.
  • Ginko
    Ginko Nov 19, 2009
    You are welcome.
    Please, do not forget the feedback.
    Thanks.
    G.
Mitsubishi 65 inch rear projector TV with remote. Model WS65807. HD ready, but not HD. Has failed circuit board, part number 930B866001. This board regulates audio and video. Part no longer available...
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Oct 25, 2017 | Mitsubishi WS-65807 65" Rear Projection...
I Need part number 930B868001 for my model WS65807 tv. Where can I get it????
That board has been discontinued for several years now. Ebay may be the only place you may still find the Signal board your needing.
Jul 11, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I have a WS65807 model proj tv .... I'm looking for part number 930B868001
Part shows as no longer available, https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=7059562 This is listed as the signal panel, are you having trouble with convergence ? Intergrated chips for this are available, part number STK392-560. You need soldering skills to replace. Most common failure on those sets. The module you ask about is not available for resale and is very expensive. I did not see one on EBay.
Jul 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a 60" rear projection Mitsubishi Tv with a "wavy" picture in the vertical direction. What may be the problem?
Hello.
You have dreaded model that build around so called V-26 chassis. It's an epic story of Mitsubishi's bad engineering several years ago. They even faced class action about it and issued recall that (of course) already expired by now. You can search web for info on court case against Mitsubishi. This particular issue is caused by faulty components in Format board that is part of the chassis. The only right way to fix it - is to remove whole chassis (sandwich of several boards in metal enclosure) and send it to Mitsubishi to get rebuilt. If you will pay someone for repair of just this board - soon others will fail as well, one of another associated issue - after unplugging TV from the wall outlet you have green blinking light forever (reboot does not come to complete).
Right now Mitsubishi lowered price for rebuilding from $640 to $320 for authorized Repair Centers nationwide. Add to it labor charge for removal/installation (at least $150) and shipping (Mitsubishi assign number for repair and send special padded box that fits chassis) at least another $50.
Also take into consideration that lamp inside of your TV sooner or later have to be replaced. It is another $150-$225.
Calculate all of this together - that's how much you have to spend to watch your TV for another 2-3 years.
Common sense would be to cut you losses and invest in new one.
As for my experience - I've removed/installed those V-26 chassis about 1000 times or so while working for Mitsubishi Authorized Center.
Hope my knowledge of this issue would help you save some money.
Regards.
Russ.
Aug 18, 2010 | Mitsubishi WD-62525 62" Rear Projection...
60pp9363h/17 tv has got convergence issues and a tech shop has it now but says they can't fix it, parts aren't available and what parts they have tried havn't worked so far?????
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 02, 2009 | Philips 60PP9363 60" Rear Projection...
Mitsubishi WS65807
The Color Signal on this Model Series travels across three boards before being sent to the CRTs. The 3DYC Board, Signal Board and the Terminal Board. Most likely, the 3DYC Board or the Signal Board is causing the problem. I have had intermittent solder connections on the 3DYC Board to cause no color problems. This Board plugs in and is located on the left front of the Signal Board as you look from the rear of the chassis. If you feel you are not up to the task to work on the set, call a Mitsubishi professional. To find one, call Mitsubishi at 1800-332-2119.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws 65857 powers off
Your set is the V17 chassis it doesnt have a DM board, your problem is most likely centerd on the main Circuit board .
Jul 24, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi ws-65807 v17 chassis
go to this websight leave an e-mail with your model number and let them know you need a signal board and they should be able to help you plus there prices are very reasonable and they also offer free online tech support to their customers
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Mitsubishi WS-65807 65" Rear Projection...
VS-60601 Mitsubishi Problem...
That model is famous for the CRts leaking onto the chassis which causes all kinds of problems and can cause the main circuit board to short as well as destroy the solder. Try looking at the board for evidence of a pastey substance that would indicate CRT coolant leakage. Let me know what you find.
Oct 24, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
