Question about Dacor DMT2420SS Microwave Oven
Microwave light appears to have burned out. How
Microwave light appears to have burned out. How do you replace it?
  • Dacor Master
  • 9,047 Answers
We would need your brand and full model number...
Posted on Nov 21, 2011
How do you repair the surface light on microwave
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when the light bulb in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. Unfortunately, a rather expensive repair for no lights. (Although the circuit board trace can usually be repaired by direct-soldering a wire to replace the burned trace. Sears repairmen won't do this, but an independent electronic technician could do it.
Apr 23, 2014 | Kenmore 62622 Microwave Oven
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
My GE JVM1540 microwave appears to run but it won't heat. The lights and turntable work but it does not heat at all.
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
May 05, 2011 | GE Spacemaker JVM1540 Microwave Oven
My microwave has a hole burned through the door.
This can start when food splatters on the inner door, then from that point the microwaves that do the cooking are attacking that splatter eventually burning a hole in the door. Do not use the microwave oven in this condition. You will need to have the door parts that are damaged replaced
May 08, 2010 | Westpoint TV-201 Microwave Oven
GE Spacesaver JVM 1651 Not heating, making burning smell
Fisrt, check to be sure your missing cat it not inside the unit. IF the interior is dirty (splatters, grease, etc.) , it may inhibit the unit from working properly.
Nov 22, 2008 | GE JVM1651 Microwave Oven
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
Louder than normal noise when using and bad 'burning' smell
You need to stop using your microwave if it's burning. This is a common symptom of a blown magnetron. Using it in it's current condition is not only dangerous, but it will further damage other components in the high voltage circuit and/or waveguide. In many circumstances, damaging the waveguide renders a microwave non-repairable. A new magnetron will cost you around $100 if you wish to repair this yourself. NOTE: I would not recommend working in or around the high voltage circuitry unless you absolutely know what you are doing. Do not attempt to take any live voltage measurements or operate the oven with any of the protective covers removed or interlocks defeated. Voltage potentials of over 13,000 volts exist and are potentially dangerous. I hope this helps you.
Feb 20, 2008 | GE JVM1660 Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
42 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
