Question about Epson Stylus RX530 All-In-One InkJet Printer
One side of paper is feeding in....
Only the right hand side of the paper is feeding into the printer. There is no errror message coming up. Please help.
  • Anonymous Mar 27, 2014
    Paper swings to right hand side then won't feed through
    Master:
  • 619 Answers
The paper loading tray have stuck something check the tray cut pieces of papers or other things /clean also the feeding rollers /w/ cotton tips one drop of rubbing alcohol.
Posted on Jan 10, 2008
MP150 paper feed not working on left hand side
Check your paper feeding roller, first clean them
Apr 30, 2012 | Canon PIXMA MP150 All-In-One InkJet...
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Tip
Paper does not feed properly
I was sick of the dreaded please load paper message I pulled the printer apart cleaned every thing to no avail. There is a roller on the right hand side where you feed the paper in. A small raised section behind the roller is used to pinch the paper between it and the roller. When this wears the paper will not feed. TO FIX Push a small piece of plastic it must be slippery (I used a 2 cm * 6 cm off an old xray) behind the roller Then use sellotape to hold it in place. No more dreaded load paper messages
on Jul 27, 2007 | Lexmark X5270 All-In-One InkJet Printer
It appears that the paper is not feeding on one side. The paper will begin to feed and then turn crooked.
First make sure that the left hand paper guide is up tight against the stack of paper in the feed tray.
If it is and the paper is still skewing then something is obstructing the path. This could be an internal part that has come loose, a piece of torn paper or a foreign object like a paperclip or wasp. Use a torch and peer down the feed chute and then look inside , examine the paper path carefully.
For info, the paper only feeds from the right side (as you look at the front of the printer)
Dec 08, 2009 | Canon PIXMA MP470 All-in-One Printer
"out of paper" message
If the printer says out of paper try to reset the printer is this does not help
then its hardware failure on the printer ,,you can try this steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck un
Feb 16, 2009 | HP PhotoSmart 7350 InkJet Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  1. Click 'OK'.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Epson Stylus RX530 All-In-One InkJet Printer Logo
88 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
