Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52631 rear projection tv. problem is that there is no picture but unit still has audio. Unit was working properly and suddenly there was a loud pop and the picture went out. the lamp in the unit appears to still be in good condition. actually changed lamp to see if this would correct the problem and the new lamp changed nothing. the tv cycles off shortly after turning it on. please advise as to what is causing this issue.
  • 2 more comments
  • WILLIANETTE FARRIESTER Nov 17, 2009
    THANK YOU
    IT HAS A 6 BLANK CODE
    1----2 1-----2
    THANKS WILL TRY AGAIN
  • WILLIANETTE FARRIESTER Nov 25, 2009
    IN REGARDS TO THE PREVIOUS MESSAGES ON THIS UNIT.
    THE "TIMER" LED IS THE ONE BLINKING
    THERE ARE TWO ERROR CODES
    12 & 66
    WE HAVE REPLACED THE BALLAST AND LAMP
    THIS DID NOT CORRECT ANY ISSUES.
    PLUG UNIT IN; HEAR IT CLICK; BUT UNIT DOES NOTHING. FANS DO NOT ATTEMPT TO COME ON NOR DOES THE LAMP.
    PLEASE ADVISE AS TO THE CAUSE OF THIS ISSUE
  • 10,594 Answers
This TV has self diagnostic feature and can tell internal problem in specific error code.
To read out error code, turn On TV, let it blinks green light until it stop, press and hold Menu & Input buttons on TV front at same time for 6 seconds, its light will start flashing in 2 sequence order, like 2 blinks, 3 blinks etc.
Let me know that blinks to check problem section and suggest solution.
Thanks.
Posted on Nov 17, 2009
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Nov 17, 2009
    THANK YOU
    Hi, appreciate your response,
    Let me explain it again,
    Light will blink two times with little pause then bigger pause.
    Suppose it blinks..... (2 times) -- (4 times) ------ (2 times) -- (4 times) ------ like that. so error code would be 24
    Please check it again and post your findings.
    Thanks.
    Need to perform error code reading process again because code 1-2 means, no error.
    As I said, turn on TV, let light blinks, may take couple of minutes, when it gets stop blinking, then proceed for error code reading procedure.
    One more thing, what LED is blinking in TV as TV has 3 LEDs at front.
    Below is an image of error codes for this TV taken from service manual that will help you.
    Thanks.
    Shahid Electronics Nov 18, 2009
    As you can see there are few codes that can shut down TV so correct error code is important to diagnose problem and suggest solution quickly.
    Thanks.
    Shahid Electronics Nov 25, 2009
    12 & 66
    66 error code, I'm afraid, problem seems in DM Board and it is qualified TV tech job to replace it. It is not user level repair because few adjustments would be done after dm board replacement.
    Please contact local tv tech for an estimate.
    Thanks.
Mitsubishi WD-52525 52" Rear Projection HDTV popped, bad picture and vibrates
The pop was a high voltage arc of electricity that blew some vital components on the main circuit board. The unit is of no use now. Repairs are far more than replacing the TV.
Feb 27, 2014 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi wd-52631 and the red light is solid I just cleaned out the tv and got a new bulb but when I turn the tv on I get about 2 mins of picture and sound before it turns off. Does any one know...
It is possible either did not get all the dirty areas in front, and rear of set cleaned out or even that the ballast for the unit is this problem since it powers the lamp---lamp will come on and then turn off for a number of reasons.
The set does have a self diagnostic feature which usually is:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 02, 2012 | Mitsubishi WD-52631 52" Projection HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
WD-52631 Audio works, but no picture
Probably a bad lamp. This is the first thing I would try....especially if the lamp has not been re[placed in awhile.
Oct 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52631 shadows and blurs in dark lit movies
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Smell from mitsubishi wd-52631
Hi...maybe I can help. Go back in and make sure your lamp is connected to the ballast. If it is not all the way in, it will smell like it is burning. Sometime it will even burn out you lamp and or ballast too. Good luck
Mar 28, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
