Question about LG LRBC22544 Bottom Freezer Refrigerator
Have a LG 3 door bottom freezer with error code Er dH. Was told by tech support to unplug for 10 mins. If this fails unit needs service. Is this correct?
Dh means defrost problem.replace defrost control and element,behind freezer panel.dont forget to unplug fridge before you work on it
Posted on Dec 06, 2009
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
The fridge is not cooling. Error ER DH showing on door. Freezer works fine. Was told that the PCB board is to be replaced as well as the defrost module. Cost will be approx $600. Can you advise o
The "Er dH," also known as the Defrost Heater Error message, is displayed when the unit fails to reach 46? F within 2 hours of beginning its defrost cycle. This may be an indication of the defrost heater having broken or the temperature fuse having been pulled out of its slot. Contact customer service if the problem persists after having attempted a system reset.
Quick Fix
  • Unplug the refrigerator for 30 seconds and then plug it back in. Doing this will reset all the codes. Sometimes an error appears by fault. If it does not appear again after restarting, then the refrigerator is fine. If the code appears again, then there is a problem with the defroster.
Defroster Problem
  • The error code itself means that the defroster mode has failed. This means that the defrost mechanism cannot reach 46 degrees Fahrenheit within two hours to defrost ice in the freezer properly. Unplug the refrigerator and move all the items that can spoil into a backup fridge or freezer.
Repair
  • Look in the back top of the freezer. Use a screwdriver to remove the ice maker machine that blocks the back defrost panel. Remove the two side screws and pull away the plastic cover guard. Check the wire. If it is unplugged, then secure it to see if that is the problem. If the plug is connected, then remove it to check for more problems. Look for any faulted wires on the defroster. If it appears that the wires are fine, you need to replace the defroster panel. Contact your local LG dealer for the specific part number
Read more: http://www.ehow.com/info_8705867_lg-refrigerator-error-code-erdh.html#ixzz2udv3MZKA
Feb 28, 2014 | LG LFC21760 Bottom Freezer French Door...
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
The door panel says "Er FF" and now it is not cooling
Er FF - Freezer Fan Error - This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Oct 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
I have error code ER dH. Unplug and then replug
Error Code - erdh
Kenmore and LG 795 Series. Model 795.77556600 but most models use the same repair. Controller Part # 6615JB2005H
To Verify correct part. Check part number for your model number at
www.searspartsdirect.com
Don't be intimidated by this repair... The 'erdh' error code indicates - error defrost heater. Replacing the controller is EASY. The difficult part is removing everything in the freezer section to access the evaporator coil but hang in there and stay with it. You will not hurt anything if you use common sense.
The new part (defrost controller) is relatively inexpensive ranging $10 - $14. Here in the SouthWest I used Appliance Parts Depot for a $10 part cost. Don't forget to have 3-4 small wire ties to secure the defrost heater, defrost sensor and wires.
It would help to write down a few notes of some of the particulars during disassembly.
I had the same ERDH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel.
(See Diagram Image) I accessed it by removing the freezer door, all components inside the freezer, including the slide rails / tracks mounted on the sides of the freezer. Be careful when removing the rear white panel because an evaporator fan is mounted on the back of it and plugs into the back left side of the freezer compartment. You just saved yourself about $375 or more.
Stay With It & Good Luck!
Feb 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a LRFC 22750 SW   LG bottom freezer with french doors.   I have been getting an error message on the digital read out ER on the refrigerator side and I think DH on the freezer side.   I  unplug...
You will get this error code if a sensor does not reach a certain temperature (+8 C, to be precise)within 2 hours of going into a defrost cycle. Increased frequency probably means the defrost build up is causing your refrigerator to run more, which will bring on the defrost cycle sooner, and the error code to repeat sooner. So, it really looks like your refrigerator is not defrosting. Soon, you will have inadequate cooling. A temporary fix to the poor cooling problem would be to unplug the refrig and open the freezer for a day or so to let it defrost on it's own, but the frost will then begin to build up again, resulting in poor cooling, depending on climate and door openings, possible in less than two weeks. Better look for service soon. If you are in the US, you can try http://us.lgservice.com/index_b2c.jsp to find service using your zip code, or call LG at 800-243-0000.
Feb 01, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRBC22544 Bottom Freezer Refrigerator Logo
705 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
