Question about Sylvania SRDV495
E4 EA03738b Recording error - E4 EA03738b Can not record on this disk. what does it mean? Double checked that I am using correct dvds - have recorded on the same type before.
SOURCE: DVD Recorder Does Not Record
It took about 45 minutes, without a manual. Carefully disconnecting all cables and marking them so the would go back in the right place later. Carefully Disassembling the unit, removing the cover - 6 screws, noting all screws and where they came from, pulling the front panel using the plastic tabs, removing the top front edge cover - two screws, removing the disk assembly - 4 screws, pulling the two thin leads so I could pull the entire assembly out. Removing the back plastic cover from the DVD assembly and identifying the Optical Disc Lense. Spraying some LENSE CLEANER on the same cloth that I clean my glasses with, and carefully wiping across - gentle stroke in same direction, then opposite direction - a few times. Spray lense cleaner on the cloth not on the lense. Reassemble. Reverse order of above. Works great now. BEST OF LUCK....Or you can find almost any DVD repair facility. This is not a unique process. Robert
Posted on Jul 01, 2007
  • 1003 Answers
SOURCE: Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Posted on Feb 02, 2008
SOURCE: What type of dvd do you need to use to record?
burned pictures on dvd and will not play
Posted on Mar 30, 2008
SOURCE: 16x DVD-R
I too need the upgrade for my Sylvania SRDV495. Could someone please send me the upgrade too or send me a link to let me know where to download if from. THANK YOU!
fifi_usa@hotmail.com
Amy
Posted on Apr 06, 2008
SOURCE: ERROR CODES
If you are trying to record from a vhs tape to a dvd, first of all you'll need to buy only 1x-8x dvd-r dvds. You can find the 4x or 8x on ebay. This recorder has a problem with the up to 16x. Put the DVD-R in and let it load. Put the videotape in. Press play on the videotape side - not dubbing but play - and let the videotape play for 6-10 seconds and THEN press the dubbing button. If you have somewhat of a lead-in on the videotape you won't lose anything. At most otherwise you'll lose 6-10 seconds. If the error code comes up, rewind the tape, and start again. Letting the videotape run for a bit first before pressing dubbing seems to prevent this problem, at least for me, and I was getting the error code every time.
Posted on May 26, 2008
Hello, My Philips DVDR7300H has a recording error after burning to dvd - burns VERY Slowly, and then gets hung on 95% - then "Disk Error" and the disk is then unreadable. It reads other previously recorded...
This happens with a number of drives.
1. DVD Dye type - but as you have tried DVDs from a batch that works seems unlikely.
2. Some drives dont like +R or -R If using +R try -R etc. Also some drives have problems with RW's used previously
3. Drive head travel is faulty. Sometimes only recording a max of 4Gb or 90% on a disk works OK.
Good Luck
Jun 10, 2014 | Philips DVDR7310H DVD Recorder / HDD...
Recorder will not let me formatt disc and says recording error e4 54039000
You can not format your hard drive while using the system on it.
Formating DVDs and CDs are not necessary to record and use them.
Windows Recorder is for voice recording to wav files not for formating discs.
Sep 13, 2011 | Computers & Internet
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD Recorder/VCR 80 GB HDD
Tyr using -r dvds ,,,,,that might resolve your problems
Mar 25, 2008 | Televison & Video
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD/VCR Emerson
Okay have had the same problem for 6 months, have bought 10 different brands and speeds of DVDs. Tried the reset idea, 5 times still no luck! I was so furstrated I was just going to buy me a new player.
Then I seen a laser lens cleaner, it was under $10 dollars at Wal mart. Came home reset the played 1st then tried the cleaning disc. I"M recording AGAIN and no error messages!
dukie 1558
Jan 22, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DSE DVD/Video rcorder G1927 error notice
I think the stupid product manufactured by Funai has some fundamental material issues that with repeated uses either the laser lens get dirty or scratched. My guess is if it is dirty a lens cleaner would get rid of it but it is a scratch or physical damage it should be repaired. Any help from Funai? Forget it....they should have probably recalled the units once the issue is known but you know how Chinese/third world countries work..
Jan 15, 2008 | Televison & Video
Dvd/vcr recorder/magnavox
my solution may be to never buy this companies products again as I have been having the same issue and since the machine is not been used much and since the disks worked before it really ticks me off. The suggestion noted to my issue recently really didn't seem to be valid due my above statted time period of no problems then sudden isses tends to show me poor quality of equipment by manufaturer.
Dec 06, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
EWR20V5 DVD Recording Error
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X to 8X or 1X to 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure.....
Aug 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Sylvania SRDV495 Logo
113 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
