Question about Chicago Pneumatic 3/8" Heavy Duty Air Ratchet CP828
My ratchet does not shut off when handle is released.
    President:
  • 2,309 Answers
Probablu the spring to shut the valve is broken or the valve us stuck, also dirt in the orifice will do that, dissassemble and repair
Posted on Dec 05, 2009
2006 Pacifica. My e-brake handle is broke off and the brake is on...how do I release it?
Clamp a large vise grip locking plier tool onto the stub and raise the handle up to release the ratchet.
Nov 11, 2016 | 2006 Chrysler Pacifica
I have a 2000 gmc Jimmy . I'm going to change the
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Oct 15, 2011 | 2000 GMC Jimmy
    How to release the spare tire on the 2005 tahoe/
    Remove your jack, and jack accessories. Open the box of accessories, and remove the ratcheting handle, and the wrench (looks like a socket on one end, and a flat screwdriver on the other end) Slide the ratcheting handle (with the side reading "down" towards you-I THINK) around the insert the screwdriver looking end of the wrench then slide the screwdriver end into the hole in your rear bumper- this lines up with a tube on the other side of the bumper and turn the ratchet. It will slowly winch down. Then you can move the toggle through the center hole of the wheel, and it will be free.
    Oct 18, 2009 | 2005 Chevrolet Tahoe
    Need to replace the serpentine belt on a 2002 Pontiac Montana
    Here's how to get a serpentine belt on or off (You'll need to do both). It's easy and doesn't require a prybar.
    On:
    • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
    • Get the belt around all the pulleys except the A/C compressor or Alternator.
    • Locate the tensioner pulley. It's one of the smaller ones and is mounted on a spring loaded arm. It's job, as the name suggests, is to keep the belt tight. Get your socket on the center nut of this pulley.
    • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
    • Slowly release the tension.
    • You're done
    Off:
    • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt off one of the pulley's (A/C or Alternator is best)
    • You're done
    Mike
    Jul 11, 2009 | 2002 Pontiac Montana
    How do i release the tension on the serpentine belt. put on a new alternator and cant release the tension of the serpentine belt
    on the tensioner you may have a square hole were you can fit a 3/8 drive ratchet if not then you may have a bolt usually 15mm where you can put a socket and swing the tensioner inorder to release tension most likely the square hole.
    Jul 08, 2009 | 1998 Chevrolet Malibu
    How do I release the belt tension pully to replace serpentine belt
    You can run down to your local auto parts store and buy a serp belt tool. Or you can take a 3/8 drive ratchet, locate the 3/8 square hole in your tensioner and put the ratchet in the hole. For more leverage I put a deep socket over the ratchet handle and put a long 3/8 extention in the deep socket. This will provide ample leverage and will save buying more tools you do not need. Simply move the tensioner to the direction that takes pressure off of the belt.
    May 24, 2009 | 2003 Chevrolet Cavalier
    I released the parking brake on my 02 Chevy Tahoe and the handle (on the dash, not center console) hyper-extended and the brake would not release. I thought I would try to pull the wire with pliers but...
    Hello all, this happend to my 2002 taboe as well. There is a handle under the dash below the steering column. The handle is conected via a cable to the parking brake foot mechanism. This cable is known to break. This part is available online through numerous websites for roughly 17-25 dollars, ebay has it but it goes for roughly 35 dollars. It is very easy to install with a pair of pliers and a wrench. The cable is about a foot long and comes with the release lever already installed.
    Mar 15, 2009 | 2002 Chevrolet Tahoe
    99 Ram 3500 parking brake
    Do you Hear the (RATCHETING Noise when you Push the Pedal Down ? If Not Its Possibly the Spring that Holds Pressure Against The RATCHET PAW on the Mechenizm itself.
    Feb 12, 2009 | 1999 Dodge Ram
    Serpentine belt
    Hi there weekie,
    Simple and easy. Really.
    • The tensioner pulley is on a spring loaded arm. Get your socket on the center nut of this pulley.
    • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt off.
    • You're done
    Mike
    Oct 26, 2008 | 2003 Toyota Corolla
    2002 focus serpentine removal
    The tensioner pully is a spring loaded arm and pully that rests against the belt.
    You will find a square hole in the arm of the pully, this will fit a 3/8" ratchet drive.
    You can use either the drive handle of a ratchet wrench, or a 3/8" drive breaker bar.
    Snap the drive handle into the hole and turn in the direction that releases tension on the belt.
    Make sure to release the arm slowly to avoid injury once the belt is off.
    Jul 30, 2008 | 2002 Ford SVT Focus
    Chicago Pneumatic 3/8" Heavy Duty Air Ratchet CP828 Logo
    297 people viewed this question
    Top Chicago Pneumatic Air Tools & Compressors Experts
    John Trevino
    Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
